You did put the # on the start of the exclude line in /etc/yum.conf?
Can you post the result
yum list clamavCode: Select all
yum list clamavyep, just updated mine and got 99.4-1.
service crond stopYou don't have to make a snapshot or backup, if you're supremely confident that can can solve any kind of problem that results from a bad update (like myself).henk wrote: 19 Mar 2018 09:28 I've got bad days on a regular basis![]()
[snip]
Make snapshot or backup.
[snip]
yum check-updateCode: Select all
service crond stop
service clamd stopCode: Select all
yum upgradeCode: Select all
rm /var/lib/clamav/daily.cldCode: Select all
freshclam -v
sa-update -vCode: Select all
yararulesproject_enabled="no"
enable_yararules="no"Code: Select all
rm /var/lib/clamav/*yar
rm /var/lib/clamav/*yara Code: Select all
service clamd startCode: Select all
freshclam -vCode: Select all
service clamd restart
Stopping Clam AntiVirus Daemon: [ OK ]
Starting Clam AntiVirus Daemon: [ OK ]
[Code: Select all
#exclude=kernel* postfix* mailscanner* MailScanner* clamav* clamd* open-vm-tools*Code: Select all
service crond stopCode: Select all
sudo yum updateCode: Select all
service crond stop
service clamd stop
freshclam -v
sa-update –v
service clamd start
