Release: error code 75 returned from Sendmail
doggy101
Post by doggy101 »
Dear fellow users,
today one of my customers tried to release a quarantine message and got a similar error:
Release: error code 75 returned from Sendmail: sendmail: fatal: xxxx@xxx.nl(48): Recipient addresses must be specified on the command line or via the -t option postdrop: warning: stdin: unexpected EOF in data, record type 78 length 76 postdrop: fatal: uid=48: malformed input
Error Messages: Y
what's wrong here?
G3 Support
Re: Release: error code 75 returned from Sendmail
Post by G3 Support »
I have the exact same error currently, need a fix
Heimir
Post by Heimir »
We have the same problem.
Release: error code 75 returned from Sendmail: sendmail: fatal: xxx@xxxxx.xxx(48): Recipient addresses must be specified on the command line or via the -t option postdrop: warning: stdin: unexpected EOF in data, record type 78 length 76 postdrop: fatal: uid=48: malformed input
Is this happening from the GUI, or the release link in the email?
dwagner
Post by dwagner »
Hey, just wanted to chime in here and say that we are having the same issue!
Yes, it is from the WebUI.
Most likely cause of this issue is how the user account is setup. Is everybody using email addresses for usernames? If not, do you have a receipient address defined for the user(s)?
dwagner
Post by dwagner »
Both users to which the email was directed have accounts on the EFA system configured as email addresses.
dwagner
Post by dwagner »
Did some digging and solved the problem. After some update the sendmail command either changed or its format for use in MailScanner did:
functions.php:9796 $cmd = QUARANTINE_SENDMAIL_PATH . ' -i -f ' . MAILWATCH_FROM_ADDR . ' ' . escapeshellarg($to) . ' < ';
If MAILWATCH_FROM_ADDR is not specified, the mail is not delivered because the -f option will consume the to address. Updated my config.php in /var/www/html/mailscanner and the issue was resolved.
Justin
Post by Justin »
dwagner wrote: 26 Apr 2018 19:16 Did some digging and solved the problem. After some update the sendmail command either changed or its format for use in MailScanner did:
How do i fix this exactly? I'm facing this issues right now and need to fix it a.s.a.p since a customer needs a email-release :shock:
just as dwagner stated:
change to valid email adress. ( you know how to use vi editor?)
and change MAILWATCH_FROM_ADDR as mentioned.
// Change with a fully qualified email address
define('MAILWATCH_FROM_ADDR', 'valid_email@example.com');
Justin
Post by Justin »
henk wrote: 24 Jul 2018 13:29 just as dwagner stated:
Aah, i missed the ' ' in the code above. Thanks for clearing that up!
Will edit and test it
