When EFA scans a zip file and finds that it contains an exe file, it sends an email to the recipient something like:
{Filename?} Lloyds TSB transaction notification #0282-497
I DO want it to find and block emails with zip files containing unacceptable attachments but I DON'T want it notifying the recipient that it has done so. Is there a way of achieving this?
Warning email for removed attachments
Re: Warning email for removed attachments
I think I understand this more now
This is what was in our config file:
# The maximum depth to which zip archives, rar archives and Microsoft Office documents will be unpacked, to allow for checking filenames and filetypes within zip and rar archives and embedded within Office documents.
# Note: This setting does *not* affect virus scanning in archives at all.
# To disable this feature set this to 0.
# A common useful setting is this option = 0, and Allow Password-Protected Archives = no. That block password-protected archives but does not do any filename/filetype checks on the files within the archive.
Maximum Archive Depth = 8
My interpretation of this is:
When the value is non-zero, any archive is opened and if it contains a file that is not allowed (eg .exe) then it strips it out and sends an email to the recipient saying what it has done. It does not bother to virus scan it because it has thrown it away.
When the value is zero, it does not strip out any zip file contents (eg .exe) but in this case it does scan them for viruses. If a virus is detected then it blocks the email but does not notify the recipient.
Am I correct?
Am I correct?
That seems accurate, although I have not tested it.
You can also modify the report sent. Look in /etc/MailScanner/reports/en for the reports.
