Hi i am new on EFA.
I want to use it to filter outgoing email.
On the web console evenif the msg is mark as CLEAN,it is on the quarantine page.
So dont really uderstand it's behaviour.
Can someone help me understand what is really the meaning of this page (quanrantne link)?
Quarantine
Re: Quarantine
It does all messages by default. You can change that behavior if you don't want it to keep a copy of clean messages.
Re: Quarantine
Ok,
Thanks for the quick answer?
What is the file conf for that? (I 'am going to search waiting your answer).
Regards,
Regards,
Re: Quarantine
A other question on quarantine:
Why a released email from quanrantine is seen coming from the admin email ?
Re: Quarantine
sudo /usr/local/sbin/EFA-Configure
Re: Quarantine
shawniverson wrote: ↑13 Jul 2018 19:229) Spam Settings --> 1) Non-Spam SettingsCode: Select all
Thanks for that, i had found it
Regards
