Some ideas for new features for V4
General E.F.A. discussion
ovizii
Post by ovizii » 05 Jun 2018 11:50
While searching for a free / open-source email encryption gateway I found this product: https://www.deeztek.com/products/hermes ... l-gateway/ which seems to combine the functionality of EFA + email archiving + encryption gateway so I thought maybe the developer of EFA could have a look for potential features to integrate into V4.
Btw. the encryption gateway integrated into the above product is https://www.ciphermail.com/
Re: Some ideas for new features for V4
Post by shawniverson » 05 Jun 2018 19:35
Version 3.0.2.6 released! Update now to keep your eFa secure!
ovizii
Post by ovizii » 06 Jun 2018 10:14
I am aware that EFA has a certain specialization and I usually prefer a single tool for a single job but sometimes its easier to use a all-in-one solution when i.e. both tools would normally handle DKIM or certificates
I am looking for something like this constellation:
internet <=> email encryption gateway <=> EFA <=> exchange <=> email client
Ciphercloud's take on it: https://www.ciphermail.com/blog/encrypt ... n-law.html (apparently they have a milter so EFA could be in front of the encryption gateway like this:
internet <=> EFA <=> email encryption gateway <=> exchange <=> email client
Anyway, this was just meant as inspiration :-)
budy
Post by budy » 06 Jun 2018 17:29
Encryption gateways are really hard to do right and in a corporate environment you usually need some assuarance if you intent to take such a contruct through a security audit.
I love eFa for all it's doing, but when it comes to encryption gateways for S/MIME or PGP, this is nothing I'd want to see in it, since I doubt that anyone having enough resources to keep that in good shape. For that you need someone who makes a business out of that.
…just my 2c, of course.
Post by pdwalker » 07 Jun 2018 07:15
I'm inclined to agree with budy here. Encryption is hard to get right and is probably best left to the client side.
budy
Post by budy » 07 Jun 2018 08:08
Uhh… client side… I could tell you lot's of stories, which suggest that leaving mail encryption with S/MIME and/or PGP to the user is simply too confusing for them to be handled right. There are a couple of really good appliances out there and the afore mentioned ciphermail was indeed on my list of encryption appliances to check out. We settled on another product, named SeppMAIL ( a swiss product ), which encrypts/singnes and decrypts our messages.
ovizii
Post by ovizii » 07 Jun 2018 09:08
Thanks for all the input. I only posted this when I found that deeztech appliance which does everything EFa does and incorporates email archiving and the encryption gateway so I thought people around here might take a look if there#s anything that could be beneficial to EFA :-)
Post by pdwalker » 11 Jun 2018 10:37
Link?
Post by henk » 11 Jun 2018 11:22
Before you decide to use encrypted email, I would read this first: https://thehackernews.com/2018/05/pgp-s ... ption.html
Link to: Breaking S/MIME and OpenPGP Email Encryption.pdf https://efail.de/efail-attack-paper.pdf
SeppMAIL : https://www.seppmail.com/secure-email/email-encryption/
ovizii
Post by ovizii » 11 Jun 2018 12:47
pdwalker wrote:
11 Jun 2018 10:37
Link?
it was my first link, sorry for not being too specific.
ovizii
Post by ovizii » 11 Jun 2018 12:50
henk wrote:
11 Jun 2018 11:22
I know about EFAIl but I only glanced over the details when I read this part:
EFF has warned users to immediately disable if they have installed any of the following mentioned plugins/tools for managing encrypted emails:
Thunderbird with Enigmail
Apple Mail with GPGTools
Outlook with Gpg4win
It should be noted that researchers have not claimed that the flaws reside in the way encryption algorithm works; instead, the issues appear in the way email decryption tools/plugins work.
