when sending out emails using the EFA, the reciepient recieves your internal network information, like your exchange/mail server FQDN and internal IP which is risky.
this is a example of my messages header before i configured the EFA. as you see it shows the name of my exchange server EX02, my WAN IP 50.20.40.66 and my lan IP 10.10.44.6
X-Greylist: from auto-whitelisted by SQLgrey-1.8.0
Received: from filter.jamerson.com (mail.jamerson.com [50.20.40.66])
     by filter.dks.com (Postfix) with ESMTPS id 1B499440061
     for <EFA@dks.com>; Mon, 14 May 2018 18:44:19 +0200 (CEST)
X-Spam-Status: No
X-jamerson-MailScanner-EFA-Watermark: 1526921060.52464@64NaYBHWK00+zhChFd6+kQ
X-jamerson-MailScanner-EFA-From: julien@jamerson.com
X-jamerson-MailScanner-EFA: Found to be clean
X-jamerson-MailScanner-EFA-ID: 4F93B400B5.AA8B6
X-jamerson-MailScanner-EFA-Information: Please contact info@jamerson.com for more information
Received: from filter.jamerson.com (mail.jamerson.com [10.10.44.6])
     (using TLSv1.2 with cipher ECDHE-RSA-AES128-GCM-SHA256 (128/128 bits))
     by filter.jamerson.com (Postfix) with ESMTPS id 4F93B400B5
     for <EFA@dks.com>; Mon, 14 May 2018 18:44:17 +0200 (CEST)
Received: from EX02.jamerson.com (10.10.44.6) by EX02.jamerson.com
(10.10.44.6) with Microsoft SMTP Server (version=TLS1_2,
cipher=TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256) id 15.1.1466.3; Mon, 14 May
2018 18:44:26 +0200
Received: from EX02.jamerson.com ([::1]) by EX02.jamerson.com ([::1])
with mapi id 15.01.1466.008; Mon, 14 May 2018 18:44:26 +0200
To: EFA B.V. <EFA@dks.com>
Subject: Re: Test
Thread-Topic: Test
Thread-Index: AQHTycJY2bz2+vxdSEihX+aRJcTDYqPr8XEpgAF91fD////JUIAhtOoQgCCOGIA=
Date: Mon, 14 May 2018 16:44:26 +0000
Message-ID: <69E4F924-312E-463F-A8C9-4D40929F41D5@jamerson.com>
References: <5b12c848a9ad43fc86418914fbb24b78@EX-DKS.DKS.lan>
<26c84ba8681c4d9ca581d96c8cff8706@jamerson.com>
<16d89b6ecfde4d6fb4c5e303fe46ff7d@EX-DKS.DKS.lan>
<4310959185664e5b80a2e72fbb977c51@jamerson.com>
<4d9bb6ba7de24eef8f22e767085afd8c@EX-DKS.DKS.lan>
In-Reply-To: <4d9bb6ba7de24eef8f22e767085afd8c@EX-DKS.DKS.lan>
Accept-Language: en-US
Content-Language: nl-NL
X-MS-Has-Attach: yes
X-MS-TNEF-Correlator:Code: Select all
50.20.40.66
mail.jamerson.com
Netherlands
10.10.44.5
(Private Network)
(Private Network)
::1
(Localhost)
(Localhost)
first go to
/etc/postfix/master.cfCode: Select all
cleanup   unix  n       -       n       -       0       cleanupCode: Select all
-o header_checks=pcre:/etc/postfix/header_checksthe result should looks like this.
#628       inet  n       -       n       -       -       qmqpd
pickup    unix  n       -       n       60      1       pickup
qmgr      fifo  n       -       n       300     1       qmgr
#qmgr     unix  n       -       n       300     1       oqmgr
tlsmgr    unix  -       -       n       1000?   1       tlsmgr
rewrite   unix  -       -       n       -       -       trivial-rewrite
bounce    unix  -       -       n       -       0       bounceCode: Select all
/etc/postfix/header_checksthe header_checks before
#                                                               HEADER_CHECKS(5)
/^Received:/ HOLD
after we replaced the code
/^Received:.*10.10.44.6/ IGNORE
/^Received:/ HOLD
restart your postfix and mailscanner services
sudo service postfix restart
sudo service mailscanner restartthe result of my message headers:
     by filter.dks.com (Postfix) with ESMTPS id 94E9E440061
     for <EFA@dks.com>; Tue, 15 May 2018 01:04:53 +0200 (CEST)
X-Spam-Status: No
X-jamerson-MailScanner-EFA-Watermark: 1526943879.4864@quXLOcZ8eoAh9G2Ls5nq+w
X-jamerson-MailScanner-EFA-ID: 48981400B5.A697C
with mapi id 15.01.1466.008; Tue, 15 May 2018 01:04:47 +0200
Subject: Re: Test IP-check
Thread-Topic: Test IP-check
Thread-Index: AQHT66dZaTN8b87MaUqqZwVsg8656qQveJ3wgAAAi4CAAACrgIAAXrqA
Date: Mon, 14 May 2018 23:04:47 +0000
Message-ID: <DC96744A-3E13-4DF3-A55D-7A30B452FC99@jamerson.com>
References: <DC932800-B896-451E-93FA-8D8F06C001C7@jamerson.com>
<5a39a22274144cb382b50044619f779c@EX-DKS.DKS.lan>
<0B7A3944-FFB6-4F33-A44A-EDEBAA62BD97@jamerson.com>
<485940b14e034daaa02c41789b5580b4@EX-DKS.DKS.lan>
In-Reply-To: <485940b14e034daaa02c41789b5580b4@EX-DKS.DKS.lan>
50.20.40.66
mail.jamerson.com
::1
(Localhost)
(Localhost)if you have any questions feel free to ask.
Please note this will be on the next release V4.
