Mailscanner plugin for checking download URLs
DeRaptor
Post by DeRaptor »
we often get mails with an embbeded download URL, wich contains either a Word/Excel/ZIP archiv infected with a virus/trojan - an example mail like this:
Dear Sirs,
here is the bill you requested:
Here is your bill
These mails pass the mailscanner / spamassassin withou recognized as spam because they are not listed in Pyzor / Razor, and these message have no further conspicuous features to catch them as spam.
Is there a MailScanner plugin, which checks the download URL, send the downloaded document through the virus scanner und informs MailScanner of the result, so that MailScanner can take further actions ?
Best regards,
Frank
Btw: i also ask the same question at the MailScanner mailing list.
Re: Mailscanner plugin for checking download URLs
Post by nicola.piazzi »
This is done automaticaly by antivirus that scans each message
EFA includes CLAM but if you want is very easy to add SOPHOS so you can have 2 engines
ovizii
Post by ovizii »
nicola.piazzi wrote: 24 Nov 2017 15:18 Hi,
Are you sure the AV covers this? I thought AV only checks attachments and not links.
interesting.
Do you have an actual link to one of these files that I could test it on?
jondo007
Post by jondo007 »
I have same question, is it possible to check and disable download links ?
We often getting spams like this one (see attached file) with download links from one drive ore something else...
