External Acces Efa
gotech
External Acces Efa
Post by gotech »
Hello:
I am new to EFA, and I would like to know the form of protection.
if there is any way to block Efa web interface abroad, or some other protection
Atte
Luis
Re: External Acces Efa
You can use a firewall ahead of eFa for that, or you can do it using iptables on eFa itself.
The way I do it is through the network firewall.
EFA has an internal IP and I only map the port 25 traffic to my efa box. I do not allow any other port mappings go to my efa server. Also, I configured my efa server to use a .local domain, so the efa box won't respond to any other domain.
