EFA-SA-update 3.0.3
buzzzo
EFA-SA-update 3.0.3
Post by buzzzo »
With the 3.0.3 update a script was placed in /etc/cron.daily to manage SA updates.
The problem is that this script expects "-cron" or "-update" option , so, by placing it directly in cron.daily it will be executed without params.
Workaround:
1) modify script to call -cron option when called without parms
2) move script out of cron.daily and put a script calling SA-update from here with -cron option.
darky83
Site Admin
Re: EFA-SA-update 3.0.3
Post by darky83 »
I also noticed this,
Will be fixed in 3.0.0.4
Well, crud, that was my bad!
The script belongs in /usr/local/sbin! *beating head off of wall now*
Also, we need to dump /etc/mail/spamassassin/kam.cf.backup from all installs
:violence-axechase:
