interesting reporting tool: sendmailanalyzer
I just came across this tool while looking for a postfix log analyzer
http://sareport.darold.net/
Installs easily and seems to work. I'm having a play with it to see if it gives me any more useful functionality.
(oh, and the tool I was looking for was https://jimsun.linxnet.com/postfix_contrib.html)
budy
Re: interesting reporting tool: sendmailanalyzer
Post by budy »
I have been using sendmailanalyzer for years and I always found it to be a good tool to have.
jogomes
Post by jogomes »
budy wrote: 28 Mar 2018 07:53 I have been using sendmailanalyzer for years and I always found it to be a good tool to have.
Hi, do you integrate it with the EFA appliance itself or just use another server to do it?
Regards.
JG
budy
Post by budy »
I have always used it only on our gateway MXs and I didn't bother with integrating it into our eFa.
since I only have one mx gateway (my efa box), I installed it on the machine directly. the changes were very minimal and shouldn't affect efa in anyway.
jogomes
Post by jogomes »
pdwalker wrote: 28 Mar 2018 09:55 since I only have one mx gateway (my efa box), I installed it on the machine directly. the changes were very minimal and shouldn't affect efa in anyway.
Thank you all,
installing it on the EFA Box is my goal, let's see.
JG
