Just deployed my first EFA Server and so far so good, however I am trying to route my mail on the OUTGOING.
I am using Exchange 2013 - where in exchange do I tell the mail to go via EFA Server?
Outgoing Mail
Re: Outgoing Mail
Okay, so I was in the correct place already but where within the Send Connector so I put in the EFA Server IP? Route mail through smart hosts?
Re: Outgoing Mail
That's strange, I inputted the EFA IP Address and went into EFA console and added in the IP Addresses of the mail servers but I then cant send mails
Re: Outgoing Mail
you need to configure the send connector - a username and password will be required to authenticate with the EFA appliance. (I think - or at least, that's what I needed to do to get it to accept email from my exchange server)
Re: Outgoing Mail
You can add the IP of your mail server(s) to the list of servers allowed to relay email through EFA. That's done through the options on SSH, under Mail Settings, then Outbound Mail Relay, then specify the list of IPs or IP/mask, separated by spaces.
Note that when you go to edit this line you'll need to re-enter the existing values - editing wipes them out..
I've found it useful to add a few specific devices to this list, most notably copiers with a return address that doesn't actually exist. That lets me send unauthenticated outbound email from those specific devices.
Re: Outgoing Mail
i am not trying to hijack the post.fencepost wrote: 28 Mar 2018 18:55 You can add the IP of your mail server(s) to the list of servers allowed to relay email through EFA. That's done through the options on SSH, under Mail Settings, then Outbound Mail Relay, then specify the list of IPs or IP/mask, separated by spaces.
i am having a sumilar
under Mail Settings, then Outbound Mail Relay i have the IP of the EFA there.
the mail server is using the EFA IP as it smarthost as well.
internl application like backup ect... cannot relay to send emails out.
mail server is sending emails out but they are coming from the mail server and not the efa.
is this a relay issue ?
Re: Outgoing Mail
I am using zimbra - where in zimbra do I tell the mail to go via EFA Server?
Re: Outgoing Mail
take a look at Configure -> Global Settings -> MTA
There, you can set the Relay MTA.
Cheers,
budy
Cheers,
budy
Re: Outgoing Mail
We're using efa for outgoing email also which is working fine but my boss asked me to check if there was a way to turn disable the spam checking in this case? Although personally I'm not sure why you might want to
Actually just realised we could presumably just whitelist our own domain & that would do the trick.
