I just came across this tool while looking for a postfix log analyzer
http://sareport.darold.net/
Installs easily and seems to work.  I'm having a play with it to see if it gives me any more useful functionality.
(oh, and the tool I was looking for was https://jimsun.linxnet.com/postfix_contrib.html)
						interesting reporting tool: sendmailanalyzer
Re: interesting reporting tool: sendmailanalyzer
I have been using sendmailanalyzer for years and I always found it to be a good tool to have.
Hi, do you integrate it with the EFA appliance itself or just use another server to do it?budy wrote: 28 Mar 2018 07:53 I have been using sendmailanalyzer for years and I always found it to be a good tool to have.
Regards.
JG
I have always used it only on our gateway MXs and I didn't bother with integrating it into our eFa.
since I only have one mx gateway (my efa box), I installed it on the machine directly.  the changes were very minimal and shouldn't affect efa in anyway.
Thank you all,pdwalker wrote: 28 Mar 2018 09:55 since I only have one mx gateway (my efa box), I installed it on the machine directly. the changes were very minimal and shouldn't affect efa in anyway.
installing it on the EFA Box is my goal, let's see.
JG
