how to exclude an user from EFA scan
hello,
in my company there is an user who does not want his emails filtered by EFA, he would like all of them to arrive directly in his inbox. I tried to disable the filter from the USER MANAGEMENT menu, but in the menu there is only the user@localdomain.local and not user@webdomain.com and it does not work anyway. All users are imported from the PDC via LDAP.
Is there a way to do that?
Thank you
Kind regards
Thank you
Kind regards
Re: how to exclude an user from EFA scan
Simpliest way is to do a header check in postfix and bypass everything for this user.
/etc/postfix/header_checks
Make sure to reload postfix
Of course, this will let everything through for this user, so you have been warned.  I don't recommend doing this.
/^To: user@example.com/ PASS
/^Received:/ HOLD
sudo service postfix reload
many thanks for support.
I tried to explain the danger of exclusion, but the user is one of the owners of the company I work for, so...
Hello
I tried to write this:
# Yorktown Heights, NY 10598, USA
# HEADER_CHECKS(5)
/^To: myuser@mydomain.mycountry/ IGNORE
/^Received:/ HOLD
and I also tried
/^To: myuser@myLocaldomain/ IGNORE
when postmap I recive a warning
/etc/postfix/header_checks, line 517: record is in "key: value" format; is this an alias file?
restart service is OK
but for user messages are still blocked as spam. where am I wrong?
# HEADER_CHECKS(5)
/^Received:/ HOLD
and I also tried
What's on line 516-518?
I'm sorry, you right. Is the line I've added
517 /^To: myuser@mydomain.mycountry/ IGNORE
518 /^Received:/ HOLD
Nothing on 515 or 516?
Try escaping the space after To:  i.e. "To:\ someone@example.com"
pdwalker, the previous lines are those of the standard file, the only thing I added is the line with the email to be excluded
shawniverson, with escape warning disappears, but messages are still blocked as spam
Thank you
 Thank you
Whoops my bad, don't postmap that thing.
Remove the header_checks.db if present in /etc/postfix and reload postfix. (I edited the above post).
Also, use "PASS" instead of "IGNORE"
Not at the top of my game today ...
I'm sorry  shawniverson,
removed header_checks.db and replaced "IGNORE" with "PASS" at end of line in header_checks
but messages still blocked
Thank you
Thank you
Is that escape "\" present?  Try it with and without.
I've tried with and without escape "\" but nothing change
Did a little research on this issue....
1) We need postfix version 3.2.x for PASS functionality.
2) \@ <----must be escaped
I am wondering if IGNORE would still work, though.
shawniverson, thank you for your support,
I noticed that the rule with IGNORE works, but the only effect it has is to remove the line To: from the header, so messages are still filtered but in the header line To: is missing. I did a research and I found this on https://posluns.com/guides/header-checks/
IGNORE will cause that particular header to be removed from the email, and will continue to process the email as normal. This can be useful in some situations. Please seethe Header Removal Guide for more information.
Is this correct to happen?
HI largo, thank you
yes, but don't work.
Re: [Solved] how to exclude an user from EFA scan
HI,
largo was right, and I was in a hurry to check workaround, whitelist from: default and to: usermail works!
Many thanks to everyone
Glad that you solved it.
/Largo
						/Largo
