create Postfix IP Blocklists
benscha
Post by benscha »
Hi Guys
i use some additional Blacklists wich i found on https://lists.blocklist.de/lists/ the lists will be updated frequently.
like for my other scripts i use the following folder structure
home/
├── root/
       ├── scripts
              ├── learn
                     ├── ham
                     └── spam
cd /home/root/scripts
#Download Mail Blacklist
wget https://lists.blocklist.de/lists/all.txt --no-check-certificate
#Add REJECT Your IP is spam
sed -i 's/$/\tREJECT Your IP is spam/g' /home/root/scripts/all.txt
#File nach postfix/client_checks kopieren
cp /home/root/scripts/all.txt /etc/postfix/client_checks
#Postmap convert
postmap /etc/postfix/client_checks
service postfix restart
rm -f /home/root/scripts/all.txt
always happy for any hints and tipps! :clap: | EFA 3.0.2.6
Re: create Postfix IP Blocklists
This blocklist looks useful.
However, I would prefer to test it out for a bit before committing to make it a regular part of my antispam shields, so I'm going to let spamassassin track how useful it is and how often it gets hit.
Adding the following to my /etc/mail/spamassassin/local.cf
## blocklist.de
header RCVD_IN_DNSBL_Blocklist_de eval:check_rbl('127.0.0.2','allinone.bl.blocklist.de')
describe RCVD_IN_DNSBL_Blocklist_de Sender listed on Blocklist DNSBL
tflags RCVD_IN_DNSBL_Blocklist_de net
score RCVD_IN_DNSBL_Blocklist_de 0.01
Let's see what it picks up over the next couple of days.
benscha
Post by benscha »
@pdwalker do you have any numbers of hits from the blocklist?
I do!
7 :lol:
On the bright side, 100% was spam!
