HowTo: Find what RBLs it is using
Another Newb Question I am sorry...
How do I find out what RBLs the system is using. My pet favourite (even after all their recent issues) is Spamhaus. But I never see it mentioned in the scores. So how do I find out which ones it is using and edit that list.
Thanks again in anticipation.
Re: HowTo: Find what RBLs it is using
Post removed (bad advice)
Hi again Shawn,
So does this mean that I need to change
to read
in order to use zen.spamhaus.org, or does this mean that it is already in use? (It doesn't appear to be)
Cheers,
Roger
Spam List = # spamhaus-ZEN # You can un-comment this to enable themCode: Select all
Spam List = spamhaus-ZEN Cheers,
Roger
Ta mate,
sorry for the dumb questions.
So by default it uses no RBLs? Why is that?
That make a bit more sense.
the logs show up to 30 emails per minute being rejected and I can't see what they're getting rejected on in prima facie if not some RBLs.
OK I'm Seriously in over my head now...
So I am looking into what RBLs SpamAssassin uses by default, and it seems it depends on Version. So I go trying to discover what SA version we are running.
it appears to be 3.003001!!! Which according to the SA Site is now way past unsupported and old.
So my question is, What SA version does it run? How do i find out what that is?
if it is 3.00xxx how to update it?
E.F.A. is on SA version 3.3.1
OK! Now I get the 3.003001 directory listing.shawniverson wrote:E.F.A. is on SA version 3.3.1
So I also assume that the EFA updates handle the SA updates and I need to just stop being nosey hey?
Don't just enable RBL' s in mailscanner.
Doing this on the MTA level (postfix) is much faster, and we already enable spamhaus by default (see /etc/postfix/main.cf)
So if you enable this in mailscanner you will be double checking and thus only slowing your system down..
Great. Thanks for weighing in darky83.darky83 wrote:Don't just enable RBL' s in mailscanner.
That make more sense again.
Is it safe to rely on having spamhaus in postfix or should one rather remove that one and rely on all the RBL checks that SA does?darky83 wrote:Don't just enable RBL' s in mailscanner.
Talking about an EFA installation for incoming emails only as I see somewarnings about using zen.spamhaus on outgoing servers => https://www.spamhaus.org/zen/
but seeing its used with smtpd_client_restrictions only it should be safe especially since permit_sasl_authenticated is set, right?Caution: Because ZEN includes the XBL and PBL lists, do not use ZEN on smarthosts or SMTP AUTH outbound servers for your own customers (or you risk blocking your own customers). Do not use ZEN in filters that do any ‘deep parsing’ of Received headers, or for anything other than checking IP addresses that hand off to your mailservers.
Depends on what you are trying to accomplish. As a general rule, the more you block at the MTA level, the better. However, if your are concerned about false positive RBLs, blocking using SA will give you an opportunity to see the mail that was blocked at the rather large expense of scanning masses of actual RBL'ed email.ovizii wrote: Is it safe to rely on having spamhaus in postfix or should one rather remove that one and rely on all the RBL checks that SA does?
that was my main concern...However, if your are concerned about false positive RBL
