build using kickstarter fails
chojin
Post by chojin »
I'm new here and wanted to install efa appliance on my home server.
I try the kickstarter build method as I intend to run the appliance in KVM+Qemu.
When CentOS installation ISO is booted with the ks= parameter, it creates all required partitions and then stops with the error
Unable to read package metadata.
Cannot retrieve repository metadata (repomd.xml) for repository: anaconda-CentOS-201703281317.x86_64.
I checked the kickstarter file and found that it uses http://centos.mirrors.efa-project.org/6/os/x86_64/ as repository however when manually trying to browse to that URL I'm prompted for a username/password which I don't find in the kickstarter file..
Also for some reason keyboard input on the machine doesn't seem to work as soon as Linux is started from the ISO hence I can't edit the repository to another centos mirror.
Is it normal that the repository is password protected? And what can I do to try to fix the installation?
cybermcm
Re: build using kickstarter fails
Post by cybermcm »
Did you ever find a solution?
I'm trying this myself and have the same error if I use the minimal iso (CentOS 6.9). If I use the netinstall iso I get
"Unable to retrieve
http://centos.mirrors.efa-project.org/6/os/x86_64//images/install.img
" There is an error with 2 "/" but even with one "/" I get unauthorized if I try this URL with a browser (username/password)
Another question:
WIKI page https://wiki.efa-project.org/doku.php?i ... stallation recommends /tmp with 1GB whereas the kickstart file (dl.efa-project.org/build/3/ks.cfg) uses 10GB. I think the WIKI is wrong/outdated?
Looks like the mirror is down at the moment. I'll check it out.
Still down :( I tried to build myself and couldn't myself. If I don't hear back from darky83, I'll update the kickstart script to point to a different CentOS repo.
cybermcm
Post by cybermcm »
still thanks for your efforts! hope you can manage it...
darky83
Site Admin
Post by darky83 »
My mistake, removed the mirror as mirror.centos.org is much faster than our own servers nowdays (when we started with the testing our mirror was next to our dev environment and thus faster for us to start testing..)
changed it now, http://dl.efa-project.org/build/3/ks.cfg now points to a working mirror.
lczirbesz
Post by lczirbesz »
The mirror url seems to changed again.
Would you be so kind to update the ks.cfg ?
--url="http://mirror.centos.org/centos/6/os/x86_64/"
