Disable spam check outgoing email
mbst83r
Post by mbst83r »
Hello guys,
how can i disable spam checking on outgoing emails?
They will be checked even if the mail is received for external transport and i want to disable this somehow.
If you need more info, just let me know.
Thanks in advance.
BR Mbst83r
jamerson
Re: Disable spam check outgoing email
Post by jamerson »
i am willing to know this too,
our internal users are facing the same issue when they send a email with attachement they got blocked.
you could whitelist your internal server or domains
jamerson
Post by jamerson »
pdwalker wrote: 12 Jan 2018 06:51 you could whitelist your internal server or domains
Thank you Paul,
I have already done this but they are still getting blocked.
not always but most of the time.
That's very strange. It doesn't happen for me.
Can you post the details of an example internal->external going message that got blocked? Both from the EFA message status page and from the message details itself?
jamerson
Post by jamerson »
pdwalker wrote: 17 Jan 2018 06:25 That's very strange. It doesn't happen for me.
Thank you pdwalker.
where can i find this excatly on the EFA page?
i have opened the blocked email and i have the message header, spam score ect...
or you mean something else ?
Thank you
Two screenshots
1/ the /mailscanner/status.php page showing an email that should be whitelisted but is not.
2/ next, show me the message details page at /mailscanner/detail.php that appears when you click on the blue circle with the i inside
3/ then show me your whitelist settings under /mailscanner/lists.php so I can check your settings against what appears under the status.php page.
In the above screenshot, I've whitelisted all mail from the ip address of the exchange server. (all users send mail to the exchange server, exchange server sends it to efa, efa sees it is whitelisted and just sends it out).
Actually, now that I think about it, I think I'll remove the whitelisting and instead use spamassassin to recognize these messages and score them with a -4.0 or something - just in case the users do something stupid.
jamerson
Post by jamerson »
Paul thank you for your help,
i've got this fixed with Spammy help.
Thank you so much guys for the support.
jamerson
Post by jamerson »
Hi Paul,
i am back with my complain
the internal users are still getting blocked when they send out emails. not always but most of them time.
i've attached a screenshot
Received: from filter.domain.com (mail.domain.com [192.168.4.5])
     (using TLSv1.2 with cipher ECDHE-RSA-AES128-GCM-SHA256 (128/128 bits))
     by filter.domain.com (Postfix) with ESMTPS id 8CEE8400C2;
     Thu, 8 Mar 2018 12:37:50 +0100 (CET)
Received: from EX02.domain.comlan (192.168.4.5) by EX02.domain.comlan
(192.168.4.5) with Microsoft SMTP Server (version=TLS1_2,
cipher=TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256) id 15.1.1415.2; Thu, 8 Mar 2018
12:35:57 +0100
Received: from EX02.domain.comlan ([::1]) by EX02.domain.comlan ([::1])
with mapi id 15.01.1415.002; Thu, 8 Mar 2018 12:35:57 +0100
To:  Coupé <coupe@domain3.com>,
     "arthur@domain2.com" <arthur@domain2.com>
CC: "initira@domain3.com" <initira@domain3.com>
Subject: FW: Transport over water 5 tanks Izegem
Thread-Topic: Transport over water 5 tanks Izegem
Thread-Index: AdO0dM7WuvmYccYJRs2xQX/LLcarNQAGLb6wADAi6TAAXcDIYA==
Date: Thu, 8 Mar 2018 11:35:57 +0000
Message-ID: <26720725e6ce4c7daf0605a21689e2a3@seoltobarging.com>
References: <AM5PR06MB31063FE64F55E15A9FB15183F6DA0@AM5PR06MB3106.eurprd06.prod.outlook.com>
<DB7PR08MB29877528A883605D6430894FE0DA0@DB7PR08MB2987.eurprd08.prod.outlook.com>
Accept-Language: nl-NL, en-US
Content-Language: nl-NL
X-MS-Has-Attach: yes
X-MS-TNEF-Correlator:
x-originating-ip: [62.140.137.134]
Content-Type: multipart/related;
     boundary="_005_26720725e6ce4c7daf0605a21689e2a3seoltobargingcom_";
     type="multipart/alternative"
MIME-Version: 1.0
on the whitelist i've added the IP of the exchange ip which is 192.168.4.5 to default see attached screenshot2
As I do not understand your setup, just want to point out that I see IPv6 EX02.domain.comlan ([::1]) and IPv4 EX02.domain.comlan (192.168.4.5). mixed for the same host.
12:35:57 +0100
In the detail section, you can see how the mail is received and the Via Ip's.
Can you post a screenshot for this message?
As I do not use IPv6, I don't know if there is a need to whitelist a IPv6 address.
Stupid question,
How do you know messages are getting blocked? Do you see this in the message log? If so, can you show me a screenshot of that?
I’ll be at a computer in about 8 hours, so I won’t be able to check anything before then.
jamerson
Post by jamerson »
Hi Paul,
i see the email is blocked as showed on the screenshot.
when the internal user send a email its get blocked as the below screenshot
jamerson
Post by jamerson »
henk wrote: 08 Mar 2018 13:07 As I do not understand your setup, just want to point out that I see IPv6 EX02.domain.comlan ([::1]) and IPv4 EX02.domain.comlan (192.168.4.5). mixed for the same host.
12:35:57 +0100
the screen of the message is the same as the info above.
i'll attached it again.
do you mean IPV6 could be the issue ?
Can you give me the spam report for that blocked message?
jamerson
Post by jamerson »
pdwalker wrote: 09 Mar 2018 16:26 Can you give me the spam report for that blocked message?
I've provided you the screenshot and report you asked for.
do you mean something else ?
If you go into the message details via the https://<your efa server>/mailscanner/detail.php?<blah blah> link, you'll see something like this:
(image clipped to only the important section)
Screen Shot 2018-03-12 at 18.35.png (146.15 KiB) Viewed 22804 times
It's the above spam report that I am interested in seeing.
Also, I noticed that your blocked line is pink, rather than a darker red. On my system, that means that the spam is only considered likely spam, and I let it through, as opposed to the higher scoring spam which I do block.
So, can you also get me the current settings of the following mailscanner settings in your /etc/MailScanner/MailScanner.conf configuration file? (the values are the settings on my system)
Required SpamAssassin Score = 4
High SpamAssassin Score = 7
Spam Actions = store deliver header "X-Spam-Status:Yes"
High Scoring Spam Actions = store header "X-Spam-Status:Yes"
Non Spam Actions = store deliver header "X-Spam-Status:No"
JohnEs
Post by JohnEs »
You know, I’ve faced the same issue recently and I still haven’t come up with any solution. Instead of it I found reliable and convenient tool to convert Netscape mail to Outlook find more details. It converts and migrates data from any email client to Outlook. Effortlessly and without a glitch. Moreover, this utility detects damages in mailboxes automatically and still manages to recover e-mails from them. Highly recommend!
^^^ spam. Could someone delete that garbage please?
