check DKIM and DMARC - how?
bostjanc
Post by bostjanc »
Hi guys.
I have implemented DKIM in EFA before upgrading it to latest version 3.0.2.6.
After I have upgraded efa server to 3.0.2.6 I saw there is a new feature for enablin DMARC and DKIM.
When I have opened that menu over ssh it saids DKIM and DMARC are disabled? I had a working DKIM environment before the upgrade, so yes I have chosen then (y) to enable DKIM&DMARC, followed all the instructions and now I am wondering is there any page, tool that I could test if DKIM and DMARC are ok?
how to test it?
with best regards
B
bostjanc
Re: check DKIM and DMARC - how?
Post by bostjanc »
Also one thing probably worth mentioning it.
When I followed enabling dmarc/dkim thru efa menu, and I typed (org): my-domain.com i saw one warning:
/var/EFA/lib/EFA-Configure/func_dkim_dmarc: line 134: [: !=: unary operator expected
Should we ignore it?
bostjanc
Post by bostjanc »
if I send a message to gmail I see this in message header:
DMARC-Filter: OpenDMARC Filter v1.3.2 efasmtp.my-domain.com 83C7113FFEF
Authentication-Results: efasmtp.my-domain.com; dmarc=none (p=none dis=none) header.from=my-domain.com
Authentication-Results: efasmtp.my-domain.com; spf=none smtp.mailfrom=testuser@my-domain.com
does this mean DMARC is set up ok?
bostjanc
Post by bostjanc »
I guess DMARC does not automatically work if I just follow EFA menu for enablin DKIM and DMARC.
Results from page: http://www.appmaildev.com/en/dkim
says:
SPF: pass
DKIM: pass
DMARC: none
DomainKey: none
DomainKey-Result: none (no signature)
If DKIM result is passed, you can ignore DomainKey result: none
what else needed to be done for enabling DMARC on efa?
I tought that following that menu would do the trick.
i am happy it did not corrupt my previous DKIM settings.
bostjanc
Post by bostjanc »
Anyone please?
This feature is for DMARC reporting.
Additional setup is required, including setup with your DNS provider, if you want eFa to have its own SPF, DKIM and DMARC.
bostjanc
Post by bostjanc »
shawniverson thanks for the reply.
The EFA menu DMARC enabling configuration is asking to put ORG:
What does ORG stand for?
is it a domain name?
