Meltdown and Spectre Vulnerabilities
Important news
Locked
In light of recently released information regarding Meltdown and Spectre, we recommend that you do the following to protect your system from this and future threats as long as CentOS 6 is supported. You should only do this if you are on version 3.0.2.6.
Update to version 3.0.2.6 and then do the following:
sudo sed -i "/^exclude=/ s/^/#/" /etc/yum.conf
sudo yum update
Restart the system after running the updates.
You may opt to leave the exclude line commented to continue updating eFa going forward using yum.
Locked
