Interesting email based blacklist
Post by nicola.piazzi »
Take a look to this
https://msbl.org
here 2 config files to put in /etc/mail/spamassassin
http://msbl.org/tools/sa-hashbl.tar.gz
I installed it 1 hour ago and i have no hits at the moment
Re: Interesting email based blacklist
Can’t hurt to try. I’ll implement it tomorrow and see what happens.
Only 11 hits in the weekend but absolutely no false positive, i ' ll increase score to 3.00
I just turned it on less than three hours ago, and I've already gotten three hits.
Excellent.
yes,
there are not a lot of hits because this is non a rbl
this is email address based so it have few entries but these are sure that is spam
Every little bit helps.
So far, I've gotten 242 messages to trigger this rule. 100% spam. Increasing the spam score to 4.0
yes, they are based on real case so hit is 100%
Alleyviper
Post by Alleyviper »
Hi there,
Where to put pm file included?
same dir where local.cf
Alleyviper
Hi Nicola,
Works like a charm :)
Check the custom phishing.bad.sites.custom to enhance event more blocking bad stuff
https://forum.efa-project.org/viewtopic.php?f=14&t=3334
ovizii
Post by ovizii »
Alleyviper wrote: 08 Jan 2019 02:57 Hi there,
I don't think its necessary to do anything. as of Sa 3.4.2 if you have /etc/mail/spamassassin/hashbl.cf look inside, mine says:
loadplugin Mail::SpamAssassin::Plugin::HashBL   HashBL.pm
ifplugin Mail::SpamAssassin::Plugin::HashBL
    header   HASHBL_EMAIL       eval:check_hashbl_emails('ebl.msbl.org')
    describe HASHBL_EMAIL       Message contains email address found on the EBL
    score    HASHBL_EMAIL       1.0
endif
then go to your EFA dashboard => Tools and Links => Spamassassin Lin (Test) then check if HASHBL_EMAIL was loaded.
mattch
Post by mattch »
Using v4 the HashBL plugin is already loaded in v342.pre but not listing any HashBL.pm file.
I commented out loadplugin for hashbl in v342.pre file, or alternatively add HashBL.pm and then comment loadplugin listed in the hashbl.cf file.
smyers119
Post by smyers119 »
mattch wrote: 22 Apr 2020 20:21 Using v4 the HashBL plugin is already loaded in v342.pre but not listing any HashBL.pm file.
Why?
Did you not see this:
15 November 2018
SpamAssassin 3.4.2 has added support for HASHBLs through its Mail::SpamAssassin::Plugin::HashBL plugin. To use the EBL with SpamAssassin 2.3.2 and later versions, you simply enable this plugin in your spamAssassin configuration. The SpamAssassin milter remains available for those using earlier versions of SpamAssassin.
Source
mattch
Post by mattch »
I did but i also get this:
Apr 23 11:02:14.523 [28636] dbg: plugin: loading Mail::SpamAssassin::Plugin::HashBL from @INC 0.00332
Apr 23 11:02:14.544 [28636] dbg: HashBL: local tests only, disabling HashBL
smyers119
Post by smyers119 »
mattch wrote: 23 Apr 2020 15:04 I did but i also get this:
That's normal, it just means it's disabled for the test, note other plugins do the same thing.
mattch
Post by mattch »
oh you're right, dcc pyzor and spamcop show disabled in the lint test.
So that means HashBL.pm file doesn't need to be referenced in the loadplugin in sa v3.4.2+, because its built-in right?
Sorry for such basic questions.
smyers119
Post by smyers119 »
That's correct, but you still need the CF file, although i haven't had 1 hit since adding it
mattch
Post by mattch »
Yeah me either and I got excited. When no hits on my spammiest users after a day I assumed it wasn't working. i suppose no hits can be considered a good thing.
smyers119
Post by smyers119 »
mattch wrote: 23 Apr 2020 16:23 Yeah me either and I got excited. When no hits on my spammiest users after a day I assumed it wasn't working. i suppose no hits can be considered a good thing.
I'll let it run a couple days then do a search to see if i got any hits. and check beck here.
smyers119
Post by smyers119 »
Ok so I checked back after 24 hours, got 3 hits, 2 were false positives. Not looking to good for this hash based block list. I'll follow it over the next week and see what happens.
the false positives were from:
3gigixgckbukyz2p0w9rzzrwp.nzxv7zyrxtoowp4z7y3st0.nzx@idverification.bounces.google.com
aka:
noreply@google.com
and
3x_2hxhekaeyvwzmxt6+nmmlxzw56owwotm.kwu@feedburner.bounces.google.com
aka:
Topic Search <noreply+feedproxy@google.com>
Note my mail volume is around 2000/day
