Upgrade from 3.0.1.5 to 3.0.2.5 mailwatch
lev
Post by lev »
Hi, I upgraded from 3.0.1.5 to 3.0.2.5 by using EFA-Update .. It looked finished successfully ..
However, when I login to mailwatch home page, there is only the header section display on the page, content or menu does not display.
any suggestions?
Thanks,
kingramon0
Re: Upgrade from 3.0.1.5 to 3.0.2.5 mailwatch
Post by kingramon0 »
I don't know if you are seeing the same problem that I was, but I solved my issue. If they are similar this might help: viewtopic.php?f=13&t=2808
lev
Post by lev »
Thanks.. I looked at the posts , but could not come up with a solution. So, I boot up my backup VM and revert back to 3.0.1.5 for now.
Will try to upgrade later again or configure a new box with latest version..
The EFA update log will tell you if and where things went off the rails. Use that to diagnose the problem next time.
