I have specified the following in /etc/ssh/sshd_config.
   PermitRootLogin no
   MaxAuthTries 3
   LoginGraceTime 5m
However, the following access logs still appear continuously from China's IP.
pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=58.218.198.146  user=root
Failed password for invalid user root from 58.218.198.146 port 25157 ssh2
My definitions on the sshd_config looks not reflected.
Why?
My env:  CentOS-6.9-x86_64-minimal.iso  with  ks=http://dl.efa-project.org/build/3/ks.cfg.
						Definition on sshd_config are not reflected
Re: Definition on sshd_config are not reflected
What are you expecting to see?
[edit]
The reason I ask is that those messages are correct. Someone tried to log in with a password but could not.
Try it yourself. Attempt to log in as root with the correct password and see if you can get in. If you cannot, then sshd is blocking the password logins, just as you would expect them to.
I've tested it on my instance and that is exactly the behaviour I am seeing. When I enable root login via password, it works just fine and disabled, I cannot log in - just as expected.
Hope that helps clear things up.
						[edit]
In the sshd of my centos 6.9 original,
if I designate them, it will not be in the log never.
Also the following iptables commands do not work too.
iptables -A INPUT -p tcp --dport 22 -j DROP ;
iptables -A INPUT -p tcp --sport 22 -j DROP ;
Is not something strange?
Ok, i don't understand what you mean exactly.
It sounds like you have two questions for two problems so you need to solve them separately.
Can you tell me exactly what you want to do any why? If I understand this, I can give you better answers.
My questions are:
why sshd_config does not work?
Why iptables does not work? I think that are same.
Why, whatever I specify,
the /var/log/secure have been recording the continuously access from China?
If sshd_config does efective, the same IP never appear consecutively.
If iptables does efective, it never be logged at all.
My destination are,
I like a server with ssh that only accepts from specific IP .
Also, I like a server with ssh that only accepts to specific user ID.
that's all.
My destination are,
that's all.
What does your iptable look like. The way you added those rules will append them after any other rule already existing and thus it is no wonder that they don't do anything…
This is my iptable setup, I haven't done much tinkering with it,except adding support for the check-mk-agent:
If I wanted to block ssh entirely, I'd rather delete rule #6, which currently allows ssh access… Issueing your iptables commands will put those way down after the REJECT rule in the INPUT chain.
[root@efa ~]# iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
ACCEPT     all  --  anywhere             anywhere            state RELATED,ESTABLISHED
ACCEPT     icmp --  anywhere             anywhere
ACCEPT     tcp  --  anywhere             anywhere            state NEW tcp dpt:http
ACCEPT     tcp  --  anywhere             anywhere            tcp dpt:check-mk-agent
ACCEPT     tcp  --  anywhere             anywhere            state NEW tcp dpt:ssh
ACCEPT     tcp  --  anywhere             anywhere            state NEW tcp dpt:smtp
ACCEPT     tcp  --  anywhere             anywhere            state NEW tcp dpt:ndmp
ACCEPT     tcp  --  anywhere             anywhere            state NEW tcp dpt:https
REJECT     all  --  anywhere             anywhere            reject-with icmp-host-prohibited
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
target     prot opt source               destinationRe: Definition on sshd_config are not reflected
I can not understand why the following specification of # 6 exists by default.
However, you pointed out the cause of this strange behavior of iptables. Thankyou!
I have to have consideration about other "smtp", "ndmp", "http" and "https" are also necessary.
If you turn off smtp, http, https access, than you could very well just shutdown your efa box, as it will be of no further use…
Yes I have understood it,  however...
> My destination are,
Now I deleted them and recreated the secure.
						> My destination are,
