Something that needs updating, really need a line between each entry on the whitelist and blacklist
I just went to delete something and its difficult to line up what you want to delete and the correct entry
No lines separating whitelist blacklist entries
Re: No lines separating whitelist blacklist entries
I agree. I'll post an enhancement to git.
I am also wondering about adding some alternating background colors to really set them apart.
cyberwired
Yeah that would be good, could really start making it nice and have an onhover or onmouseover and highlight the line when you mouse over
very easy:
First cp /var/www/html/mailscanner/lists.php /var/www/html/mailscanner/lists.php.bak <--- BACKUP
Then edit lists.php
Put on the top just after html_start("Whitelist/Blacklist",0,false,false);
the following:
(These are the two colours you would like to use in the rows )
Next modify the function build_table as follow:
Add just after function build_table($sql,$list) :
And then replace the while code with:
Then edit lists.php
the following:
$bgcolor1 = "#BDBDBD";
$bgcolor2 = "#D8D8D8" ;
global $bgcolor1,$bgcolor2;
while($row=mysql_fetch_row($sth)) {
$i++;
$bgcolor= ( $i %2 == 0 ) ? $bgcolor1 : $bgcolor2 ;
echo ' <tr>'."\n";
echo ' <td bgcolor='.$bgcolor.'>'.$row[1] . '</td>'."\n";
echo ' <td bgcolor='.$bgcolor.'>'.$row[2].'</td>'."\n";
echo ' <td bgcolor='.$bgcolor.'><a href="'.$_SERVER['PHP_SELF'].'?submit=Delete&id='.$row[0].'&to='.$row[2].'&list='.$list.'">Delete</a><td>'."\n";
echo ' </tr>'."\n";
cyberwired
Fantastic cheers
shawniverson: something to add to next version?
Awesome, will add this and recommend change to upstream mailwatch devs....
https://github.com/E-F-A/v3/issues/57
