yes/no decision toggles
i would like to see all yes/no decisions either be always capital, or always lower case. right now we have a mix of the two, and its difficult to memorize which one its going to be depending on what task i am performing
Re: yes/no decision toggles
Can you provide some examples of where this is happening? Honestly, I've never even noticed this before.
Are you sure you want to reboot this host?
Y) Yes I am sure
N) No no no take me back!
[EFA] : y
Error "y" is not an option...
example, the greylisting toggle accepts lower case.
Y) Yes I am sure
[EFA] : y
Menu changes are coming in 3.0.2.6, including standardization of selection options!
