Image of EFA 3.0.2.5
snit_gary
Post by snit_gary »
Hello, does anyone know if there is a vhd image of the latest EFA or where I can get an image of an older version?
The latest update killed one of my clients EFA and they are using 2008 R2 Hyper V so they can't use vhdx.
Re: Image of EFA 3.0.2.5
When you say, "killed", can you be a bit more specific? Do you believe the system is truly unrecoverable?
TheGr8Wonder
Post by TheGr8Wonder »
https://mirrors.efa-project.org/images/ ... HyperV.zip
But I agree with pdwalker, what broke during the upgrade?
snit_gary
Post by snit_gary »
Thanks for the link!
After the upgrade the mailscanner and postfix services wouldn't start stating that it couldn't find them.
I noticed /etc/rc.d/init.d/mailscanner was actually missing. I did copy from another EFA I have running which worked but still had issues with postfix for a while, my colleague managed to get that working but now the web front end doesn't work but webmin is up and fine. I've tried to fix it but to be honest I've spent to long on it now. Rather just re-download and start again. Thanks anyway.
snit_gary
Post by snit_gary »
Sorry I was a little premature :roll:
The link is for a .vhdx, do you have a .vhd of the image?
Your best bet will be to run a build on a hyper-v instance.
https://wiki.efa-project.org/doku.php?id=building_e.f.a
