I got a lot of spams for my registered domains, about seo expiration.
So, I made a rule in /etc/mail/spamassassin/local.cf:
header BAD_WORD_SEO Subject =~ /(SEO|Expiration)/i
score BAD_WORD_SEO 4.0
Then you need to run "sa-compile" and "/etc/init.d/mailscanner restart".
Now, if subject contains SEO and Expiration it will get a score of 4.0.
(Similar works for other keywords as well.)
Regards,
Andras
SEO Expiration spam
Re: SEO Expiration spam
Ahh great - just what I needed…
Thanks,
budy
Thanks,
budy
I've never had to do an sa-compile to add new rules into my local.cf, so (and someone please correct me if I am wrong) I don't think it is necessary.
You are right. sa-compile is not required.
I also modified the rule:
header BAD_WORD_SEO Subject =~ /(Expiration SEO)/i
The original one filtered out everything with either expiration or SEO in it.
The new one just filters out if "Expiration SEO" is in the subject.
Regards,
Andras
Regards,
Andras
There is a way to specify (A and B) rather then (A or B) or (A B) which may be more useful.
Have a look through the existing rule sets and you should be able to find the syntax.
