It does and that is the version I have installed.  Something must be broken in my dependencies database, because I can see the same thing:
[root@efa spamassassin]# yum deplist perl-File-MimeInfo
Finding dependencies:
 * EFA: dl.efa-project.org
 * base: ftp.cuhk.edu.hk
 * epel: kodeterbuka.beritagar.id
 * extras: ftp.cuhk.edu.hk
 * rpmforge: mirrors.digipower.vn
 * updates: ftp.cuhk.edu.hk
package: perl-File-MimeInfo.noarch 0.25-1.el6
  dependency: perl(File::DesktopEntry) >= 0.04
   provider: perl-File-DesktopEntry.noarch 0.08-1.el6
   provider: perl-File-DesktopEntry.noarch 0.04-1.el6.rf
  dependency: /usr/bin/perl
   provider: perl.x86_64 4:5.10.1-141.el6_7.1
  dependency: perl(Fcntl)
  dependency: perl(strict)
  dependency: perl(Exporter)
  dependency: perl(File::BaseDir) >= 0.03
   provider: perl-File-BaseDir.noarch 0.03-13.el6
   provider: webmin.noarch 1.770-1
   provider: perl-File-BaseDir.noarch 0.03-1.el6.rf
  dependency: shared-mime-info
   provider: shared-mime-info.x86_64 0.70-6.el6
  dependency: perl(Carp)
   provider: perl-Devel-Carp.noarch 0.04-1.2.el6.rf
  dependency: perl(:MODULE_COMPAT_5.10.1)
  dependency: perl(File::Spec)
   provider: perl-PathTools.x86_64 3.30-1.el6.rf
   provider: perl-File-Spec.x86_64 3.30-1.el6.rf
  dependency: perl(bytes)
Interestingly, I have a second package listed
package: perl-File-MimeInfo.noarch 0.15-1.el6.rf
  dependency: perl
  dependency: perl(File::MimeInfo)
   provider: perl-File-MimeInfo.noarch 0.25-1.el6
   provider: perl-File-MimeInfo.noarch 0.15-1.el6.rf
which does not have that dependency, and is not installed.
Weird.
Anyway, like I said, according to the notes on ole2macro.pm, having that module is not essential.
