[EFA] : 14
[EFA] Good you are root
[EFA] Starting update to EFA-3.0.2.5
Setting up Update Process
* EFA: dl.efa-project.org
* base: mirror.rackspeed.de
* epel: vesta.informatik.rwth-aachen.de
* extras: mirror.eu.oneandone.net
* mariadb: fr.mirror.babylon.network
* updates: mirror.tobias-wollmann.com
http://fr.mirror.babylon.network/mariadb/yum/10.1/centos6-amd64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 7 - "Failed to connect to 2001:41d0:8:4480::221: Network is unreachable"
Trying other mirror.
No Packages marked for Update
Your system has an updated kernel, but you are not running
on the latest kernel. Please restart your system and run
EFA-Update after restart.
After the reboot, eFa still showed 3.0.2.4, which may be caused by the abnormal exit of the update script.
Yeah - but that doesn't solve the issue of the mariadb repo being unavailable and thus even after a reboot, the systen still says 3.0.2.4.
I have not yet tried another repo for that, but that repo is - as of now - unavailable.
Based on the above message, I see an attempt to connect to the repo using ipv6 instead of ipv4, which it should not be doing.
You can also temporarily disable the mariadb repo in /etc/yum.conf.d to allow 3.0.2.5 update to proceed and work on updating the mariadb binaries later.
Yes, it tried ipv6 - don't know either, why it did that. I do now have 3.0.2.5 installed, but I had to reboot twice. Once after the initial update, which downloaded and installed the new kernel, but didn't create a new initrd. That had been done one the next reboot, which is why the system didn't perform the update to 3.0.2.5. After the 2nd reboot, I was able to update to 3.0.2.5.
Usually, I am used to create the new initrd as the last step after downloading/installing the new kernels, so I probably assumed that this would be the same case here. In that case, one reboot would have sufficed.
