I can boot using the older kernel from the GRUB menu. Tried the update a couple of times - same issue each time.
Many thanks
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/vg_00-lv_root
8.4G 3.1G 4.9G 39% /
tmpfs 2.1G 0 2.1G 0% /dev/shm
/dev/sda1 508M 166M 316M 35% /boot
/dev/mapper/vg_00-lv_tmp
1.1G 2.8M 967M 1% /tmp
/dev/mapper/vg_00-lv_var
22G 3.6G 17G 18% /var
none 2.1G 50k 2.1G 1% /var/spool/MailScanner/incoming
rpm -q kernel
kernel-2.6.32-642.13.1.el6.x86_64
kernel-2.6.32-696.el6.x86_64
kernel-2.6.32-696.1.1.el6.x86_64
kernel-2.6.32-696.3.1.el6.x86_64
kernel-2.6.32-696.10.2.el6.x86_64
package-cleanup --oldkernels --count=1
rpm -e 'newkernalnamehere'
