Upgraded with no issue but on restart this clam av problem piped up I am a windows guy so please be kind any help will be much apreciated
Error messages after upgrade
- EFA Error.png (105.82 KiB) Viewed 4114 times
Re: Error messages after upgrade
The first errors can be addressed like this:
The other "errors" are benign and can be ignored for now.
sudo rm /var/lib/clamav/main.cvd
sudo rm /var/lib/clamav/bytecode.cvd
thankyou for your help
