I'm not bad with php etc but the way this is put together isn't what I'm used to, having trouble finding where things are
I want to put the date and time on the same line, so its more compact, and the Recent Messages, Lists etc bar, I want to compact that also
Where would I do that?
How can I modify the web console?
Re: How can I modify the web console?
This is something we want to do in an next release
This is located somewhere in functions.php, but I have not found the right section just yet
(have not spend any time on it..)
No worries, I am going to duplicate the Message Listing and Message Operations formatting here
cyberwired
I'm embarrassed to say this stared me in the face for way too long and I just kept missing it
/var/www/html/mailscanner/status.php
Change (it may differ slightly on this, I removed it then can't go back)
To
Basically remove the <br> in the middle there
DATE_FORMAT(timestamp, '".DATE_FORMAT."<br>".TIME_FORMAT."') AS datetime, To
DATE_FORMAT(timestamp, '".DATE_FORMAT." ".TIME_FORMAT."') AS datetime, -
cyberwired
And to make that big bar smaller, open style.css, go down to #menu and change height from 40 to 20, padding from 10 to 5, then #menu li a line-height from 40 to 20
cyberwired
I just realised on smaller monitors this doesn't quite do the trickcyberwired wrote:I'm embarrassed to say this stared me in the face for way too long and I just kept missing it
Change (it may differ slightly on this, I removed it then can't go back)Code: Select all
ToBasically remove the <br> in the middle thereCode: Select all
editing functions.php I added
if ($fieldname[$f]=="Date/Time"){ $cellwidth = " width='125'"; } else { $cellwidth = ""; } Code: Select all
// Column headings
echo '<tr>'."\n";
for($f=0; $f<$fields; $f++) {
if($display[$f]) {
if($order && $orderable[$f]) {
// Set up the mysql column to account for operations
if ($operations != false) {
$colnum = $f-1;
} else {
$colnum = $f;
echo " <th>\n";
echo " $fieldname[$f] (<a href=\"?orderby=".mysql_field_name($sth,$colnum)."&orderdir=a".subtract_multi_get_vars(array('$
echo " </th>\n";
} else {
echo ' <th'.$cellwidth.'>'.$fieldname[$f].'</th>'."\n";
}Code: Select all
echo ' <th>'.$fieldname[$f].'</th>'."\n"; Code: Select all
