Remove signature problem
EFAai
Post by EFAai »
I'm having problems removing the signature for clean messages. I have tried the option 9/3 from the menu, and deleted the domain, but this doesn't seem to work. Is there an other solution, or workaround?
Thanks for all the effert put in this great project.
EFAai
Re: Remove signature problem
Post by EFAai »
With a quick DuckDuckGo search I found the soluction: viewtopic.php?t=675
For those who are wondering, start the EFA Configuration program and chose 9) Spam Settings/ 1) Non Spam Settings, choose the default N (Don't disable storing spam) and then Y (DISABLE non spam signatures)
