After Update logoff after 3 Minutes
uwejanssen
Post by uwejanssen »
After updating to 3.0.1.9, we have the problem that we automatically fly out of the web interface after 3 - 4 minutes, afterwards comes with some functions the "Sicherheitstoken" is wrong. Where can I turn off autologoff for the web interface?
Greeting from Germany
Uwe
Re: After Update logoff after 3 Minutes
This doesn't sound like an autologoff issue. The latest mailwatch logs off automatically after 60 minutes, not 3-4 minutes. It sounds like your session is dropping for some reason, from perhaps an unstable connection or something.
uwejanssen
We have this Problem from Frankfurt and from Oldenburg and from other Places, i think it is not the connection.
It is on 2 Systems one on Xen and one on VMWare, in front of the Update we don´t have this problem.
Uwe
Have you made sure existing clients have cleared cache completely? Old copies of mailwatch pages will cause this as well.
Do you have an aggressive garbage collection setting in your php.ini?
uwejanssen
We have isntall with your Install Script, we don´t have change something in the php.ini
Uwe
I'm not sure why you get a 3 minute logoff, but nonetheless, we are planning to release version 3.0.2.0 that hopefully will solve this issue for you.
Hopefully resolved in 3.0.2.0.
BruceLeeRoy
Post by BruceLeeRoy »
I have a new installation from a few days ago v3.0.2.3 using the .ovf I'm getting auto logged off rather quickly, could be about 3 minutes, but it only happens if I'm jumping between tabs, if I stay on the EFA tab in the browser it seems to stay logged in.
Update: the user timeout setting in v3.0.2.3 works nicely Thank you :D
alexanderbrix
Post by alexanderbrix »
after updating to the latest build today I got the same problem again. I'm getting logged out every few minutes while staying on the "Recent Messages" tab...
Very annoying :(
alexanderbrix
please provide an update or a workaround - it's really annoying being logged out every few minutes...
Edit your user account in MailWatch and set your timeouts to "0"
alexanderbrix
thank you!
