EFA Unbound and reverse DNS.
Post by henk » 06 Aug 2017 13:05
The current EFA setup enables the Unbound DNS server. Dns queries are forwarded to our own dns server(s).Works fine.
However when I want to query local addresses or reverse dns it doesn't work on the EFA server. :?
Test dns forwarding on the EFA server
dig test.uribl.com.multi.uribl.com txt +short
"permanent testpoint"
or
dig  2.0.0.127.zen.spamhaus.org +short
127.0.0.4
127.0.0.2
127.0.0.10
But dig with any fqdn in my internal zone(s) fails. Same for reverse DNS
dig sambaad.example.com +short
or reverse dns sambaad.example.com (172.16.1.117)
dig -x 172.16.1.117  +short
Since every situation is different it's quite difficult to give an example that will fit all. I sure would like some info from those who have knowledge from Unbound and how they configured it. Please let me know.
The working setup: (No need to mention that the network/Zones must match your configuration :!: )
In my network I have 3 DNS servers.
1.The primary DNS, SAMBA4 AD server running Bind-9. Authoritative for Example.com and forwarding to The PFsense server.
2.The secondairy DNS and gateway: PFsense also running Unbound for DNS and forwarding to my providers DNS servers.
3.The EFA server forwarding everything to the first 2 DNS servers depending on the zones.
All servers have muliple interfaces in different zones but I will remove the other interfaces and zones from this example.
The Ip addresses are not the actual Ip's, but just for making sense in this example.
SAMBA4 AD requires to be the primary DNS server to function properly, since AD and DNS are very close related :roll:
It took me some time to get DNS working to resolve internal zones.
On all my internal networks IPv6 is disabled.
On the primary SAMBA4 AD Server Running BIND-9:
acl internals {
    127/8;
    172.16.0.0/16;       AKA LAN Network
On the EFA server:
cat /etc/resolv.conf
search example.com.
nameserver 127.0.0.1
nameserver 172.16.1.117 # SAMBA4 AD
nameserver 172.16.1.61 # PFSENSE
Forward all queries to the pfsense box
cat /etc/unbound/conf.d/forwarders.conf
forward-zone:
forward-addr: 172.16.1.61 # PFSENSE
forward-first: yes
Modifications in /etc/unbound/unbound.conf
# restrict DNS EFA
interface: 127.0.0.1
outgoing-interface: 172.16.1.115 # LAN Interface EFA
# Enable IPv4, "yes" or "no".
do-ip4: yes
# Enable IPv6, "yes" or "no".
do-ip6: no
control-interface: 127.0.0.1
# Forward zones
forward-zone:
forward-addr: 172.16.1.117 # SAMBA4 AD
forward-first: yes
server:
local-zone: "16.172.in-addr.arpa." nodefault
stub-zone:
stub-addr: 172.16.1.117 # SAMBA4 AD
Restart Unbound and try:
for i in $(seq 1 5); do dig +noall +answer +stats A sambaad.example.com | sed -n '1,2p'; done
dig -x 172.16.1.117
Re: EFA Unbound and reverse DNS.
Post by pdwalker » 07 Aug 2017 06:32
Thank you. I was just thinking about setting this up a couple of minutes ago, but you've already done all the hard work of figuring it out.
Much appreciated!
Re: EFA Unbound and reverse DNS. authoritative or not
Post by henk » 12 Aug 2017 21:24
Usefull Note: There is a difference between forward zones and stub zones - stub zones will only work when connected to an authoritative DNS server directly. This would work for lookups from a BIND DNS server if it is providing authoritative DNS - but if you are referring queries to an unbound server in which internal lookups are forwarded on to another DNS server, then defining the referral as a stub zone in the machine here will not work. In that case it is necessary to define a forward zone as above, since forward zones can have daisy chain lookups onward to other DNS servers. i.e. forward zones can refer queries to recursive DNS servers. This distinction is important as you do not get any error messages indicating what the problem is if you use a stub zone inappropriately.
The link: https://wiki.archlinux.org/index.php/un ... ng_queries
Change from stub to forward zones:
forward-zone:
      forward-addr: 172.16.1.117               # SAMBA4 AD with Bind9 as dns
      forward-first: yes
forward-zone:
server:
       local-zone: "16.172.in-addr.arpa." transparent
restart unbound:
service unbound restart
Check dns:
unbound-host -C /etc/unbound/unbound.conf -v sambaad.example.com
Aug 12 21:43:12 libunbound[11839:0] notice: init module 0: iterator
sambaad.example.com has address 172.16.1.117 (insecure)
sambaad.example.com has no IPv6 address (insecure)
sambaad.example.com has no mail handler record (insecure)
Post by shawniverson » 19 Aug 2017 23:24
Post by henk » 31 Aug 2017 17:58
The blessings of conf.d to not touch the original unbound.conf provided by efa.
/etc/resolv.conf
search example.com.
forward-zone:
  forward-addr: 172.16.1.61      # Pfsense
  forward-first: yes
/etc/unbound/conf.d/unbound.conf
# The server clause sets the main parameters.
server:
        do-ip4: yes
        cache-min-ttl: 900
        hide-identity: yes
        hide-version: yes
        private-domain: "example.com"
        private-address: 172.16.0.0/16
        # control which clients are allowed to make (recursive) queries
        access-control: 127.0.0.0/8 allow
remote-control:
# Forward zones
forward-zone:
      forward-host: sambaad.example.com        # SAMBA AD
      forward-first: yes
forward-zone:
      forward-first: yes
For those who want to add some or a lot unbound statistics to munin: https://www.unbound.net/documentation/h ... stics.html
Check stats:
unbound-control stats_noreset
bug-fix EFA Unbound and reverse DNS.
Post by henk » 26 May 2018 07:52
Had some strange issues resolving some local dns names on EFA. The check: viewtopic.php?t=3032
As EFA uses 127.0.0.1 as nameserver, and Unbound uses conditional forwarding to the pfsense box or the samba4 box, it's strange that it works in this last example. ( there is no entry for samba4 in /etc/hosts)
Unbound should not be able to resolve the example.com dns names without the resolved IP from sambaad.example.com in the first place.
A restart of unbound will fix it, but it makes no sense. After some time, Unbound can not resolve sambaad.example.com. ( that makes sense)
This is a complete mystery for me. Sure like to know if someone can explain this. :think:
To fix this I changed the forwarder hostname to forwarder IP address, bypassing the resolve of sambaad.example.com.
forward-addr: 172.16.1.117            # SAMBA AD
To check the dns sequence and caching, use tcpdump on the outgoing interface, and dig some local hosts and some outside your network.
tcpdump -i eth1 port 53 -X
It sure improves resolving hostnames and eliminates the dns ping pong.
