Pyzor Questions
thewomble
Pyzor Questions
Post by thewomble »
I noticed that the Pyzor on the latest EFA is version 0.7, while version 1.0 is available.
Do you know of a reason to not move to 1.0?
Also where are of the configuration files, I was looking add "pyzor.scrolloutf1.com:24441" as another server to the default.
Re: Pyzor Questions
Documentation on pyzor can be found here:
http://www.pyzor.org/en/release-1-0-0/config.html
Short answer: create a "servers" file in the .pyzor configuration directory and add in your list of servers:ports, one per line.
You can then test to see if spamassassin works by running this command:
echo "test" | spamassassin -D pyzor 2>&1 | less
and look for lines like:
Jul 26 19:29:05.278 [8807] dbg: pyzor: pyzor is available: /usr/bin/pyzor
Jul 26 19:29:05.279 [8807] dbg: pyzor: opening pipe: /usr/bin/pyzor check < /tmp/.spamassassin8807DMeMrDtmp
Jul 26 19:29:05.668 [8807] dbg: pyzor: [8819] finished: exit 1
Jul 26 19:29:05.668 [8807] dbg: pyzor: got response: public.pyzor.org:24441 (200, 'OK') 2455164 79513
Jul 26 19:29:05.669 [8807] dbg: pyzor: listed: COUNT=2455164/5 WHITELIST=79513
You can also use "pyzor ping" to see if pyzor can connect to a pyzor server successfully. For what it's worth, I was not able to connect to the server you listed above, but that might be normal if it is a private server.
Where does the configuration directory go? I don't know for sure. I assume it will go in the user directory that spamassassin runs under which I guess is postfix, thus would be: /var/spool/postfix/.pyzor
Give it a try and see if it works, and let us know how you get on.
Re: Pyzor Questions
thewomble wrote: 25 Jul 2017 13:17Do you know of a reason to not move to 1.0?
Other than the fact that efa is developed almost entirely by one person who does it in his spare time? No, none.
I assume that when v4 rolls out, that a lot of the packages will be replaced with newer versions, including pyzor.
thewomble
Re: Pyzor Questions
Post by thewomble »
With regards to version 1.0 it was more a question of any dependances that anybody was aware of.
I have going to download and have a play and report back once was working.
Pyzor is working, Pyzor ping works.
Tried /var/spool/postfix/.pyzor
also tried /var/spool/MailScanner/spammassassin
but Pyzor ping only reports the default server.
Re: Pyzor Questions
The configuration file has to be in the home directory of the user. What user are you running pyzor ping as?
Re: Pyzor Questions
pdwalker wrote: 26 Jul 2017 11:35
This is true, very true.
TheGr8Wonder
Re: Pyzor Questions
Post by TheGr8Wonder »
To add additional Pyzor nodes to your setup, you will need to create a servers file at /var/spool/postifx/.pyzor/servers
nano /var/spool/postfix/.pyzor/servers
Add the servers you want...
Save the file. Once saved you'll need to update permissions on it (based on the build.bash script)
chown -R postfix:apache /var/spool/postfix/.pyzor
chmod -R ug+rwx /var/spool/postfix/.pyzor
The new servers will then be added for checks and reports when dealing with spam.
Re: Pyzor Questions
for what it is worth, I cannot access pyzor.scrolloutf1.com, but public.pyzor.org works fine.
TheGr8Wonder
Re: Pyzor Questions
Can you add 'pyzor.nova53.net:24441' to your list and give it a try again?
Re: Pyzor Questions
That one works.
Who are they?
TheGr8Wonder
Re: Pyzor Questions
Sent you a PM
Re: Pyzor Questions
Which raises a question. Does EFA/Mailscanner/Spamassassin submit any hashes to the pyzor server?
TheGr8Wonder
Re: Pyzor Questions
It will when checking the message at first, to see if it matches. It will not submit new hashes unless you choose the SA option of "SPAM+Report", and it will upload the hash of the spam message to all pyzor servers listed in your server file.
Re: Pyzor Questions
Thank you, I didn't know that.
ovizii
Re: Pyzor Questions
Post by ovizii »
TheGr8Wonder wrote: 07 Aug 2017 22:23 To add additional Pyzor nodes to your setup, you will need to create a servers file at /var/spool/postifx/.pyzor/servers
After doing that, how do I make sure that servers file is actually being used by EFA? I manually tried running pyzor ping as postfix but couldn't do that so I wondered how to make sure that config is actually being used?
TheGr8Wonder
Re: Pyzor Questions
You can add another server that is used as well,
You can run this...
And you should see near the top that you get a "Ok" response from servers listed in that file.
ovizii
Re: Pyzor Questions
Post by ovizii »
You can run this...
CODE: SELECT ALL
thanks but running that line I am running it as root so does it use /var/spool/postfix/.pyzor/servers? I assume it does not.
TheGr8Wonder
Re: Pyzor Questions
You are correct, it will not work as root. You will need to start a new SSH session with EFA, enter the shell, then run that command without elevating to root first. :)
TheGr8Wonder
Re: Pyzor Questions
The result you are looking for...
Aug 12 09:52:26.550 [12987] dbg: pyzor: got response: public.pyzor.org:24441 (200, 'OK') 2587478 80480\n (additioanl servers)
and when the test is done, type this to exit the result
:q
ovizii
Re: Pyzor Questions
Post by ovizii »
yes, correct, but it will obviously only look for the servers inside /root.pyzor/server and not inside the servers file we have edited.
ovizii
Re: Pyzor Questions
Post by ovizii »
TheGr8Wonder wrote: 12 Aug 2017 13:51 You are correct, it will not work as root. You will need to start a new SSH session with EFA, enter the shell, then run that command without elevating to root first. :)
I don't think so, if I don't elevate to root I am using the account which was created when setting up EFA and that is not the account which EFA uses to check mails either.
TheGr8Wonder
Re: Pyzor Questions
The test command is my bad. It's called via mailscanner directly. the location we modded is that used by postfix and apache, so that is the right one. You will need to reboot the EFA after changing the file, to restart the services, and then check the mail logs. The location does work, however.
Re: Pyzor Questions
Since pyzor runs as postfix, we have to update the postfix account pyzor configuration file. Here's my complete test run.
[root@efa .pyzor]# su - postfix
This account is currently not available.
[root@efa .pyzor]# chsh postfix
Changing shell for postfix.
New shell [/sbin/nologin]: /bin/bash
Shell changed.
-bash-4.1$ pwd
/var/spool/postfix
-bash-4.1$ vi .pyzor/server
-bash-4.1$ chmod a+r .pyzor/server # may not be necessary, depending on your settings, but doesn't hurt
-bash-4.1$ pyzor ping
pyzor.scrolloutf1.com:24441 (200, 'OK')
pyzor.nova53.net:24441 (200, 'OK')
-bash-4.1$ logout
New shell [/bin/bash]: /sbin/nologin
Shell changed.
The postfix account does not normally allow logins, so I enabled logins while I tested it, and then disabled it immediately afterwards.
Here is the results of the pyzor check after running it on a spam message
Aug 15 15:09:29.313 [4385] dbg: pyzor: got response: public.pyzor.org:24441 (200, 'OK') 17 0\npyzor.nova53.net:24441 (200, 'OK') 0 0\npyzor.scrolloutf1.com:24441 (200, 'OK') 12 0
Aug 15 15:09:29.314 [4385] dbg: dns: leaving helper-app run mode
Aug 15 15:09:29.314 [4385] dbg: check: tagrun - tag PYZOR is now ready, value: Reported 29 times.
Aug 15 15:09:29.315 [4385] dbg: pyzor: listed: COUNT=29/5 WHITELIST=0
If you're using multiple pyzor servers, then it might make for better spam detection if we reported the pyzor value (29 reports in this case) rather than true/false. E.g. the greater the number of reports, the more likely it is to be spam.
I've not figured out how to do that yet though.
edit: (found it, that didn't take too long)
short of editing /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Plugin/Pyzor.pm and changing the return value of "sub pyzor_lookup" from 1 to $pyzor_count after a successful lookup.
Hmmm, I should find the SpamAssassin people and suggest that as a change, or have them add it as a new return value option if requested.
edit 2: submitted: https://bz.apache.org/SpamAssassin/show_bug.cgi?id=7458
efa-user
Re: Pyzor Questions
Post by efa-user »
Looks like a useful addition, and the following is an interesting read regarding how not to sort scores:
http://www.evanmiller.org/how-not-to-so ... ating.html
thewomble
Re: Pyzor Questions
Post by thewomble »
Wow this as been busy while I been away on leave.
I notice pyzor.nova53.net is listed, is this a look source to add to the setup?
Is the pyzor.scrolloutf1 worth adding for those that have tested it?
