clamd CPu is at 100%
I hit an issue where CLAMD is hitting 100%. i have no idea why CLAMD is doing this. is there a way to look at clamd logs?
please let me know.
please let me know.
Re: clamd CPu is at 100%
guys looks like im getting this error in the /var/logs/maillogs/
Jul 24 11:50:06 COSMTPAP01P MailScanner[3200]: Virus and Content Scanning: Starting
Jul 24 11:50:06 COSMTPAP01P MailScanner[3200]: Clamd::ERROR:: COULD NOT CONNECT TO CLAMD, RECOMMEND RESTARTING DAEMON :: .
Jul 24 11:50:07 COSMTPAP01P MailScanner[3200]: Virus Scanning: Clamd found 1 infections
Jul 24 11:50:07 COSMTPAP01P MailScanner[3200]: Virus Scanning: No virus scanners worked, so message batch was abandoned and retried!
I believe this is what is causing my CPU to go up.
Please HELP.
Please HELP.
not sure if this related. I have 30+ processes containing the following:
etc/spamassassin/imageCerberus/imageCerberusEXE --textdetector /etc/spamassassin/imageCerberus/WholeWord.xml --load /etc/spamassassin/imageCerberus/data --classifyF /tmp/sa_imageCerberus_tmpImg.2500.png
what is this?
what is this?
attached is a screenshot of the error when i reboot the server.
- clamd.png (431.23 KiB) Viewed 17707 times
in processes i see like Image Cerberus taking all the CPU. why is this happening? Screenshot is attached.
- 2017-07-24_21-25-25.png (336.57 KiB) Viewed 17697 times
It sounds like you have some funny messages in your mail queue that are causing the scanners to go a bit nuts.
Is there a way you could forward one of those messages to me so I can check it on my own system?
Those errors are harmless and can safely be ignored.
i just got these emails.
Service clamd down and restarted ( 1 attempts in past day, max attempts is 3 )
Please examine your EFA logs on <Server Name> and resources to determine cause of failure
Is there such thing as EFA Logs?
Let me know.
Let me know.
i notice that /imageCerberusEXE is taking all my CPU. What is /imageCerberusEXE? i just use EFA as an internal SMTP relay. Can i just disable it?
imageCerberusEXE is a program designed to "read" graphic images to determine if they are spam, as some spammers use gifs/pngs/jpegs to send spam messages to defeat spam detection software, so it is useful.
Turning it off may allow more spam to come in. I guess that editing /etc/mail/spamassassin/ImageCerberusPLG.cf and commenting out the following line with a "#" character will do the trick:
Unfortunately, in your case, you've seem to have gotten a "special" message that blows up clamd and imageCerberus, so disabling imageCerberus will not stop your problem with ClamD. Or maybe it will if the imageCerberusEXE executable is not running.
Try it and let us know the results. It'll be interesting to find out what is in the message that is causing things to break.
loadplugin ImageCerberusPLG /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Plugin/ImageCerberusPLG.pm Try it and let us know the results. It'll be interesting to find out what is in the message that is causing things to break.
I wish i would now how to check what message is doing this. but there is nothing stuck in the queue and CPU is at 100%.pdwalker wrote: 26 Jul 2017 11:13 imageCerberusEXE is a program designed to "read" graphic images to determine if they are spam, as some spammers use gifs/pngs/jpegs to send spam messages to defeat spam detection software, so it is useful.
Turning it off may allow more spam to come in. I guess that editing /etc/mail/spamassassin/ImageCerberusPLG.cf and commenting out the following line with a "#" character will do the trick:Unfortunately, in your case, you've seem to have gotten a "special" message that blows up clamd and imageCerberus, so disabling imageCerberus will not stop your problem with ClamD. Or maybe it will if the imageCerberusEXE executable is not running.Code: Select all
kill those imageCerberusEXE processes and see if the problem comes back.
