eFa 3.0.2.6 Update Final Released
Posted: 02 Jan 2018 16:47
The 3.0.2.6 update is now available.
We would also like to thank everyone for their support and contributions to this project.
This is likely the final update to eFa version 3. 2018 development will be shifted to version 4.
The following issues have been fixed (hopefully) in 3.0.2.6:
Issue #345 Bug - Numeric phishing default ruleset needed
Issue #360 Enhancement - Update option -- Are you Sure?
Issue #364 Enhancement - Edit transport destinations
Issue #374 Enhancement - Option to bypass db backup during update
Issue #382 Bug - Allow square brackets in EFA-Configure
Issue #395 Bug - postmap postfix configs during system restore
Issue #396 Bug - Fix case-sensitive strings in Let's Encrypt
Issue #397 Enhancement - Include hostname in upgrade email notices
Issue #399 Bug - POSTMASTEREMAIL undefined on some instances
Issue #400 Bug - Identical files scanning bug in multiple attached archives
Issue #401 Enhancement - Better kernel update detection
Issue #402 Bug - /usr/bin/clamav-unofficial-sigs.sh config version not updated to required version
Issue #403 Bug - MailGraph image in footer causing mixed content messages
Issue #405 Enhancement - Update hosts file when Outbound Relay is added
Enhancement -- sort friendly backup names
Enhancement -- remote-build.bash script for vps/remote builds
MailScanner updated to 5.0.7-1
Remi repo upgrade to PHP 7.2 added for performance and security
###################### How To Update ##################################
3) If the update fails for any reason, collect relevant logs or screen
outputs/screenshots and revert to your snapshot
Launch EFA-Configure from console or secure shell
(sudo /usr/local/sbin/EFA-Configure)
Choose option 14) Update Now
continue the update process to 3.0.2.6.
if present.
if present.
