EFA 3.0.1.5 Update
Important news
Locked
EFA 3.0.1.5 Update
We would also like to thank everyone for their support and contributions to this project. :clap:
(Please see the following post before upgrading if you are using multiple AV scanners)
viewtopic.php?f=13&p=6953
This minor update includes a few fixes since the 3.0.1.4 release.
VMware Image
https://dl.efa-project.org/build/3.0.1. ... VMware.zip
md5: 3b955ccd6e5ea3b5e8bba44a2362970c
sha1: a1521b1cd0bac6117d5fc9507990d53fc84f687a
(Hyper-V builds are pending...)
Updates is available from prior versions now.
The following issues have been fixed in 3.0.1.5:
Issue #299 Enhancement - Enhance menus in EFA-Configure (allow back out)
Issue #320 Bug - /root/.spamassassin inaccessible
Issue #322 Enhancement - Geoip update during EFA-Init
Issue #323 Bug - clamav-unofficial-sigs not running
Please review the RELEASENOTES prior to updating for important information:
https://raw.githubusercontent.com/E-F-A ... LEASENOTES
3) If the update fails for any reason, collect relevant logs and output/screenshots,
then immediately roll back to snapshot
Log into a console or shell section and use EFA-Configure.
Choose option 14) Upgrade
To manually launch from shell:
sudo /usr/local/sbin/EFA-Configure
continue the update process to 3.0.1.5.
if present.
Locked
