EFA 3.0.1.2 Released!
Important news
Locked
We would also like to thank everyone for their support and contributions to this project. :clap:
(Please see the following post before upgrading if you are using multiple AV scanners)
viewtopic.php?f=13&p=6953
VMware Build Available (webmaster is ooo, so posting here for now):
https://dl.efa-project.org/build/3.0.1. ... VMware.zip
MD5: f8bc3b683a9686505857e545d608e865
SHA1: 1e5bd5fe4bb832c39acd301d127d66d840dbfa31
(Hyper-V build is pending...)
Updates is available from prior versions now.
The following issues have been fixed in 3.0.1.2:
Issue #92 Bug/Enhancement - Mailwatch Single Recipient Release
Issue #165 Enhancement - Upgrade MailScanner
Issue #206 Enhancement - Default Max Archive Depth to Non Zero
Issue #210 Enhancement - Add EFA Version to GUI
Issue #228 Bug - Greylist toggle overwrites custom smtpd_recipient_restrictions
Issue #232 Enhancement - Use CLAMAV-UNOFFICIAL-SIGS maintained by eXtremeSHOK.com
Issue #239 Enhancement - Add TxRep Config for SA 3.4.1
Issue #265 Enhancement - Add per user mode for MailWatch
Issue #267 Bug - SPAM bounce loop
Issue #275 Bug - MailWatch updater adds duplicate SHOW_GREYLIST definitions
Issue #284 Enhancement - Lower ImageCerberus Scores by default
Issue #276 Bug - EFA-Configure Option 11 logic error
Issue #286 Bug - Postmaster set to empty interferes with postfix
Issue #287 Regression - Rules without Descriptions (removed from beta)
Issue #294 Bug - Attachment Release Issues in MailWatch
Issue #297 Bug - KAM.cf URL needs updated
Issue #306 Enhancement - EFA-Monitor alert enhancement
Please review the RELEASENOTES prior to updating for important information:
https://raw.githubusercontent.com/E-F-A ... LEASENOTES
3) If the update fails for any reason, immediately roll back to snapshot
Log into a console or shell section and use EFA-Configure.
Choose option 14) Upgrade
To manually launch from shell:
sudo /usr/local/sbin/EFA-Configure
continue the update process to 3.0.1.2.
if present.
Locked
