Build E.F.A from scratch.
Posted: 20 Oct 2012 19:18
by darky83
If you want to use E.F.A on direct hardware instead of a VM you will need to build E.F.A from a build script.
A bit of Linux (Debian) knowledge is required to get this working.
Currently there is no bootstrap script available so you will need to install Debian 6.0.x (x86) your self with the following settings during installation:
  • Create the root user with password: password
  • Create the user: efaadmin
  • password for user efaadmin: password
  • Disk setup (the use of LVM is recommended, below settings are guidelines but are not required a single / could work.):
  • - minimum 6GB /
  • - minimum 1GB /tmp (set noexec & nosetuid)
  • (if you don't want a separate /tmp partition you need to comment the two DPkg: lines in the build script)
  • - minimum 12GB /var
  • - minimum 20GB /var/spool
  • Software installation: SSH Server & Standard system utilities
After the OS is installed and is booted login as root.
Now download and execute the build script:
wget http://www.efa-project.org/build/0.3/build.sh
chmod 700 build.sh
./build.sh
During the installation you will be asked to configure mysql answer these as followed:
  • Configure MySQL (1): yes
  • Configure MySQL (2): yes
The system will automatically reboot and is ready for configuration (the configure script will automatically be launched when you login as root the first time).
Good luck!
Re: Build E.F.A from scratch.
Posted: 08 Nov 2012 22:34
by Mach3
Pretty much everything barring Baruwa installed on the Raspberry Pi
Posted: 27 Nov 2012 23:19
by levon
I followed these instructions and I get the following errors...
web page
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, [no address given] and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Apache/2.2.16 (Debian) Server at 192.168.10.121 Port 80
apache2/baruwa-error.log
[Wed Nov 28 01:14:54 2012] [error] [client 192.168.10.213] DatabaseError: (1146, "Table 'baruwa.django_session' doesn't exist")
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] mod_wsgi (pid=632): Exception occurred processing WSGI script '/usr/share/pyshared/baruwa/baruwa.wsgi'.
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] Traceback (most recent call last):
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] File "/usr/lib/pymodules/python2.6/django/core/handlers/wsgi.py", line 245, in __call__
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] response = middleware_method(request, response)
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] File "/usr/lib/pymodules/python2.6/django/contrib/sessions/middleware.py", line 36, in process_response
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] request.session.save()
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] File "/usr/lib/pymodules/python2.6/django/contrib/sessions/backends/db.py", line 56, in save
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] session_key = self.session_key,
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] File "/usr/lib/pymodules/python2.6/django/contrib/sessions/backends/base.py", line 152, in _get_session_key
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] self._session_key = self._get_new_session_key()
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] File "/usr/lib/pymodules/python2.6/django/contrib/sessions/backends/base.py", line 144, in _get_new_session_key
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] if not self.exists(session_key):
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] File "/usr/lib/pymodules/python2.6/django/contrib/sessions/backends/db.py", line 29, in exists
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] Session.objects.get(session_key=session_key)
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] File "/usr/lib/pymodules/python2.6/django/db/models/manager.py", line 132, in get
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] return self.get_query_set().get(*args, **kwargs)
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] File "/usr/lib/pymodules/python2.6/django/db/models/query.py", line 336, in get
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] num = len(clone)
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] File "/usr/lib/pymodules/python2.6/django/db/models/query.py", line 81, in __len__
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] self._result_cache = list(self.iterator())
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] File "/usr/lib/pymodules/python2.6/django/db/models/query.py", line 269, in iterator
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] for row in compiler.results_iter():
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] File "/usr/lib/pymodules/python2.6/django/db/models/sql/compiler.py", line 672, in results_iter
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] for rows in self.execute_sql(MULTI):
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] File "/usr/lib/pymodules/python2.6/django/db/models/sql/compiler.py", line 727, in execute_sql
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] cursor.execute(sql, params)
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] File "/usr/lib/pymodules/python2.6/django/db/backends/mysql/base.py", line 86, in execute
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] return self.cursor.execute(query, args)
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] File "/usr/lib/pymodules/python2.6/MySQLdb/cursors.py", line 166, in execute
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] self.errorhandler(self, exc, value)
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] File "/usr/lib/pymodules/python2.6/MySQLdb/connections.py", line 35, in defaulterrorhandler
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] raise errorclass, errorvalue
[Wed Nov 28 01:15:14 2012] [error] [client 192.168.10.213] DatabaseError: (1146, "Table 'baruwa.django_session' doesn't exist")
Posted: 28 Nov 2012 07:57
by darky83
It seems that the database or tables do not exist in mysql for baruwa.
This will most likely be because you did not use the password 'password or made a typo in one of the usernames or passwords.
Posted: 05 Dec 2012 16:08
by Mach3
darky83 wrote:This will most likely be because you did not use the password 'password or made a typo in one of the usernames or passwords.
I can confirm this as I made the same mistake.
Posted: 29 Jan 2013 01:44
by rhostager
Do you recommend the amd64 or i386 version of Debian or does it not matter?
Rob
Posted: 29 Jan 2013 09:20
by darky83
Hi Rob,
Currently all is build on x86, never tested on amd64.
Good point I will add this to the howto.
d.
Posted: 29 Jan 2013 12:51
by ge2000
I recently installed EFA with SQLgrey and webmin on debian 6.0.6 amd64.
Beside two minor problems (no relation to platform) with exec permissions of a script and an apache2 config everything installs and runs fine.
So no problems on 64bit systems :)
--Ge
Posted: 24 May 2013 08:03
by ge2000
In addition to my previous post I can add that I have succesfully installed EFA on Ubuntu 12.04.2 LTS (64Bit).
Problems I had where:
- the install script tries to install (mysql)versions that are not in the Ubuntu repo
- rabbitmq had to be reconfigured as mentioned in other posts
- baruwa user/password had to be corrected afterwards
- Apache2, WSGIScriptAlias location corrected in config
- apparmor had to be modified to enable clamav scanning
So despite these minor issues everything works fine now.
