I am familiar with MailScanner - been using it for years. I really like this virtual appliance, and baruwa. Here's a problem I have discovered. I edited /etc/MailScanner.conf, and changed the low scoring action to store deliver, but it doesn't work, it only stores, will not deliver. I have restarted MS, after moddifying the config file. Any ideas?
Spam Actions
Re: Spam Actions
Further to this, it seems like no setting changes I make in /etc/MailScanner/MailScanner.conf are taking effect. I had set it up to quarantine infected files, but that doesn't change either. I checked, and rechecked MailScanner.conf, and it has the correct settings. I have restarted MailScanner (several times), rebooted the server, but the changes that I make to MailScanner.conf do not appear to work.
Any ideas?
Any ideas?
Re: Spam Actions
Figured out that there is a conf.d folder in the MailScanner folder, and in there, baruwa.conf. I made the changes there...had to add the lines from MailScanner.conf that had to do with quarantining an infected file (silent, and normal).
Hopefully this helps someone else.
