My 'archive' list is empty, does this feature need to be enabled or is there a problem?
Archive empty
Re: Archive empty
Emails older than 2 months will appear under archive. If your EFA appliance hasn't been running for 2+ months it indeed will be empty. Everything should be fine if you can see the mailflow.
