Customising quarantine email URLs
Posted: 30 Dec 2012 11:48
by DavidRa
Is there a supported way to customise the links in the quarantine emails? I am running EFA as (effectively) a hosted appliance behind a NAT firewall. As a result, all the links in the email are to:
http://INTERNAL_IP/messages/release/MSG_GUID/
For example (less obfuscated):
http://10.0.0.3/messages/release/123456 ... 890abcdef/
I'd really prefer to have the URL use a defined name (antispam.domain.com, for example) so that I can release messages without having to VPN into the hosting network. It may be that I failed to set up the appliance correctly - but I do not remember seeing settings related to this (other than the computer name of the appliance, which does not appear to be used in the emails). Having said that I also do not see any use of the hostname defined in Baruwa setup - which is a short name, not a FQDN (a problem, perhaps?)
I checked out /usr/share/pyshared/baruwa/settings.py and the QUARANTINE_REPORT_HOSTURL contains the IP address - so changing it there looks like it would fix the emails, but I suspect that running efa-configure (e.g. as part of a version upgrade) might .. "break" it again?
Happy to provide further information - if someone can tell me what I can usefully provide.
Re: Customising quarantine email URLs
Posted: 30 Dec 2012 16:03
by darky83
I was planning to add this as an option to efa-configure
in efa-configure I will use the following command to change the line:
sed -i "/^QUARANTINE_REPORT_HOSTURL = / c\QUARANTINE_REPORT_HOSTURL = 'http://1.1.1.1' " /etc/baruwa/settings.py
So I search for ^QUARANTINE_REPORT_HOSTURL = and change everything behind the line, so if you use the above command and change 1.1.1.1 to your hostname you should not break any future configure items in efa-configure.
Posted: 30 Dec 2012 17:49
by darky83
Just added this to the EFA-Configure script..
You can try it out by downloading the development version:
cd /tmp
wget https://raw.github.com/darky83/EFA/master/Build/0.3/usr/local/sbin/EFA-Configure.bash
chmod 700 EFA-Configure.bash
./EFA-Configure.bash
Posted: 30 Dec 2012 23:51
by DavidRa
OK I checked the emails this morning; not only does the link now point to the hostname desired, the error text that used to accompany the "Release" link has vanished too. Win-win!
Old "Release" content:
MailScanner has detected a possible fraud attempt from "INTERNAL_IP" claiming to be Release
New "Release" content:
Release
Also, I tried the EFA-Configure script to change it and it successfully updated /etc/baruwa/settings.py (the file to which /usr/share/pyshared/baruwa/settings.py is linked, just in case anyone is confused by the different files we referred to) so that looks good.
Thanks Darky!
