I'm getting the following error during the build of perl-Compress-Raw-Zlib-2.027-1.noarch.rpm within the build.bash script.
Is this anything to worry about?
error: Arch dependent binaries in noarch package
RPM build errors:
Missing file /root/rpmbuild/RPMS/noarch/perl-Compress-Raw-Zlib-2.027-1.noarch.rpm.
Maybe it did not build correctly?
rpm build errors during build.bash
Re: rpm build errors during build.bash
this is during the build of mailscanner and can be ignored,
Mailscanner causes a whole bunch of errors but the script will make sure that all needed packages are installed up front.
