Very Quick LDAP integration
Widmo
Post by Widmo »
I've done small blog post:
http://blog.widmo.biz/postfix-check-use ... tory-ldap/
I think it's so easy to implement, maintain, configure, that should be included in project.
Cheers.
buzzzo
Re: Very Quick LDAP integration
Post by buzzzo »
This is good and bad:
GOOD: no need to user relay_recipient map and thus the need to create a script to populate it
THE BAD: if someone tries to ddos your postfix gateway you have two side effects:
a) down of the postfix gateway
b) down of your internal ldap server flooded by the ldap query
MITIGATION: use proxymap on postfix gateway side.
Widmo
Post by Widmo »
c) comment line in postfix with queries to ldap.
buzzzo
Post by buzzzo »
your c) is supposed to be bad ?
