I am thinking of implementing EFA into our existing exchange 2010 environment and I need some insight on the following
* Does EFA have the functionality to archive copies of clean emails for either administrators or users to access, and if so what duration
* does EFA work ok in conjuction with Piler (mailpiler.org)
many thanks
EFA functionality
Re: EFA functionality
By default, EFA will archive all emails for 30 days (this can be changed).
Piler *should* be ok, although I have not specifically tested it. Depending on your environment, I'm thinking Piler would be best suited to forward from Exchange to Piler instead of EFA to Piler, so that you can capture all internal messages. EFA wouldn't be a factor in that case. Just a thought.
Thank you very much
That gives me something to go on
