How to enable IPV6
Woger
How to enable IPV6
Post by Woger »
After updating EFA, it seems to have diabled the ipv6.
When I try to enable it from console I get a "eth0 is nog an active interface" error. But it's the only interface, and an ifconfig show a ipv4 and ipv6 address.
Can I enable it by manually? Changing ifcg-eth0 to IPV6INIT="yes" didn't help.
Thanks,
Roger
Woger
Re: How to enable IPV6
Post by Woger »
Found out that the ip addresses were configured on eth1 and that interface was disabled. Enabling the eth1 solved the problem.
