scamnailer
Re: scamnailer
Oooh..this looks very interesting.
Currently EFA does not have these.
I'm am going to give this a try and report back. We may want to include these in an upcoming release.
Re: scamnailer
Hmm...the scamNailer script seems to fail for me...going to try the clamav signature instead
I am working with: Current: 2014-053 - 16 and Status: -1 - -1
This is base update
Unable to retrieve http://www.mailscanner.tv/emails..2014-053 :404 Not Found
Update required
Retrieving http://www.mailscanner.tv/emails.2014-053.1
Failed to retrieve http://www.mailscanner.tv/emails.2014-053.1 at ./ScamNailer-2.09 line 276.
Retrieving http://www.mailscanner.tv/emails.2014-053.2
Failed to retrieve http://www.mailscanner.tv/emails.2014-053.2 at ./ScamNailer-2.09 line 276.
Retrieving http://www.mailscanner.tv/emails.2014-053.3
Failed to retrieve http://www.mailscanner.tv/emails.2014-053.3 at ./ScamNailer-2.09 line 276.
Retrieving http://www.mailscanner.tv/emails.2014-053.4
Failed to retrieve http://www.mailscanner.tv/emails.2014-053.4 at ./ScamNailer-2.09 line 276.
Retrieving http://www.mailscanner.tv/emails.2014-053.5
Failed to retrieve http://www.mailscanner.tv/emails.2014-053.5 at ./ScamNailer-2.09 line 276.
Retrieving http://www.mailscanner.tv/emails.2014-053.6
Failed to retrieve http://www.mailscanner.tv/emails.2014-053.6 at ./ScamNailer-2.09 line 276.
Retrieving http://www.mailscanner.tv/emails.2014-053.7
Failed to retrieve http://www.mailscanner.tv/emails.2014-053.7 at ./ScamNailer-2.09 line 276.
Retrieving http://www.mailscanner.tv/emails.2014-053.8
Failed to retrieve http://www.mailscanner.tv/emails.2014-053.8 at ./ScamNailer-2.09 line 276.
Retrieving http://www.mailscanner.tv/emails.2014-053.9
Failed to retrieve http://www.mailscanner.tv/emails.2014-053.9 at ./ScamNailer-2.09 line 276.
Retrieving http://www.mailscanner.tv/emails.2014-053.10
Failed to retrieve http://www.mailscanner.tv/emails.2014-053.10 at ./ScamNailer-2.09 line 276.
Retrieving http://www.mailscanner.tv/emails.2014-053.11
Failed to retrieve http://www.mailscanner.tv/emails.2014-053.11 at ./ScamNailer-2.09 line 276.
Retrieving http://www.mailscanner.tv/emails.2014-053.12
Failed to retrieve http://www.mailscanner.tv/emails.2014-053.12 at ./ScamNailer-2.09 line 276.
Retrieving http://www.mailscanner.tv/emails.2014-053.13
Failed to retrieve http://www.mailscanner.tv/emails.2014-053.13 at ./ScamNailer-2.09 line 276.
Retrieving http://www.mailscanner.tv/emails.2014-053.14
Failed to retrieve http://www.mailscanner.tv/emails.2014-053.14 at ./ScamNailer-2.09 line 276.
Retrieving http://www.mailscanner.tv/emails.2014-053.15
Failed to retrieve http://www.mailscanner.tv/emails.2014-053.15 at ./ScamNailer-2.09 line 276.
Retrieving http://www.mailscanner.tv/emails.2014-053.16
Failed to retrieve http://www.mailscanner.tv/emails.2014-053.16 at ./ScamNailer-2.09 line 276.
Unable to open base file (/var/cache/ScamNailer/cache//2014-053)
This is base update
Update required
Re: scamnailer
I think the fastest and simplier way to integrate into EFA is via the clamav way...
Re: scamnailer
Re: scamnailer
Yep, just downloaded the rules and dropped them in. Looks like it is working. It just caught a fake Bank of America alert that was fake.
Going to add this as an enhancement.
Re: scamnailer
very simple script to update:
/usr/local/bin/clamav-scamnailer-sigs.sh:
#!/bin/sh
url="http://www.mailscanner.eu/scamnailer.ndb"
wget="/usr/bin/wget"
target_dir="/var/clamav"
output_file="scamnailer.ndb"
clam_user="clamav:clamav"
$wget --quiet $url -O "$target_dir/$output_file"
chown $clam_user "$target_dir/$output_file"
put somewhere in /etc/cron.d:
55 * * * * root /usr/local/bin/clamav-scamnailer-sigs.sh >> /var/log/clamav-scamnailer-sigs.log 2>&1
Don't know if clamd needs to be informed that the sigs should be reloaded.
Thx
#!/bin/sh
Thx
Re: scamnailer
Better script to avoid re-download of the same file:
#!/bin/sh
tmp_dir="/var/cache/scamnailer"
start_date=`date`
mkdir -p $tmp_dir
cd $tmp_dir
echo "Getting signature file from scamnailer site ..."
$wget $url -N > $tmp_dir/log 2>&1
echo "done."
result=`cat $tmp_dir/log | grep -i 'not retrieving' | wc -l`
if [ $result -eq "1" ] ; then
stop_date=`date`
echo "Remote sig $output_file is like the local one: NO DOWNLOAD. EXIT NOW"
echo "Start Update Date: $start_date"
echo "Finish Update Date: $stop_date"
exit 1
fi
echo "Copying new $output_file to $target_dir ..."
cp "$tmp_dir/$output_file" $target_dir
echo "done."
stop_date=`date`
#!/bin/sh
start_date=`date`
mkdir -p $tmp_dir
cd $tmp_dir
echo "done."
stop_date=`date`
exit 1
fi
echo "done."
stop_date=`date`
Re: scamnailer
Great! I'll add this to the enhancements.
Re: scamnailer
Actually, you can skip the script.
Just add this line in freshclam.conf
DatabaseCustomURL http://www.mailscanner.eu/scamnailer.ndb
During freshclam update it will also check for this file, test and then trigger clamd to re-read the ndb(s).
Regards,
Michael
Regards,
Michael
Re: scamnailer
Good but actually it depends from how you update the sign.
Seems to be 2 method that runs in parallel:
1) freshclam
2) mailscanner scripts
In my opinion is better to use the "standard" mailscanner way.
In this case if the mailscanner script is simply a wrapper around freshclam so customdburl should work.
1) freshclam
Re: scamnailer
So what is the current status of scamnailer inclusion?
Is scamnailer included in EFA 3.0.1.1?
How is it fetched and updated?
Re: scamnailer
Scamnailer is there.
Check /var/log/clamav-unofficial-sigs.log for details
