Ipv6 disabled but detected
tesme33
Post by tesme33 »
just fresh installed and Efa.
First i thought lets at least enable IPV6 DNS but my VM doesnt get an IPv6 adress.
So i disabled it . See eFA configure output as shown below.
But i still get the following error message on the main login page:
MailWatch for MailScanner v1.2.15 running on eFa-4.0.3 ...ERROR INITIALIZATING IPV6, CHECK INTERNET ACCESS... - © 2006-2021
---        Welcome to the eFa Configuration program        ---
---               https://www.efa-project.org              ---
Current and Proposed IP settings for eth0 are:
         SETTING         :        CURRENT             :         PROPOSED
 1) BOOTPROTO            :  none                      :  none
 2) IPV6_AUTOCONF        :  yes                       :  yes
 3) IP                   :  93.ccc.66.83  93.ccc.66.83
 4) Netmask              :  255.255.252.0             :  255.255.252.0
 5) Gateway              :  93.ccc.64.1               :  93.ccc.64.1
 6) Use IPv6 DNS         :  no                        :  no
 7) IPv6 IP              :                            :
 8) IPv6 Prefix          :                            :
 9) IPv6 Gateway         :                            :
10) DNS Recursion        :  ENABLED                   :  ENABLED
11) Primary DNS          :                            :
12) Secondary DNS        :                            :
13) Hostname             :  efa4                      :  efa4
14) Domain Name          :  xxx.de             :  xxx.de
y) Make changes
c) Cancel
e) Return to main menu
Re: Ipv6 disabled but detected
Turn off IPV6 autoconf
buset1974
Post by buset1974 »
edit vi /usr/sbin/eFa-Post-Init
locate row with contain this line
wget -q --tries=3 --timeout=20 --spider https://ipv4.efa-project.org
add parameter --no-check-certificate on it
so it will be
wget -q --tries=3 --timeout=20 --spider https://ipv4.efa-project.org --no-check-certificate
I'm not sure why you would need to do that unless something is up with your certificates :/
