Thanks for all your efforts in this project, it's most appreciated.
I have a question about the OVF format. I have downloaded and installed the VMWare OVF tool and am using VMWare Server 2.0 running on a WinXP 64bit machine.
My question is, how do I convert the OVF file to suit my instance of VMWare?
Duke
OVF How To?
Re: OVF How To?
Please note the OVF has not been tested on VMware Server 2.
However, it has been tested on VirtualBox and works well.
You can try using the OVF Tool from VMware to see if you can convert the OVF.
https://www.vmware.com/support/developer/ovf/
